what's wrong with this line
Results 1 to 6 of 6
    Jun 2011
    Indian Harbour Nova Scotia
    Default what's wrong with this line
    I'm trying to use someone else's assembler code for a project and managed to get 55 compile errors down to one; the following errors out with "illegal opcode":
    #config
    _CONFIG _INTRC_OSC_NOCLKOUT &_WDT_OFF & _LVP_OFF & _CP_OFF
    #endconfig
    this is for a 16F628A MCU. If I take out the _INTRC_OSC_NOCLKOUT, then it errors on the next configuration bit.
    I'm using PBP3.0 and the MPASM assembler (I think).
    _INTRC_OSC_NOCLKOUT is not in the PBP inc file, but it is in the MSPASM inc file. Both have the WDT and LVP bits.
    I'm new at this...
    Default Re: what's wrong with this line
    There should be two underscore infront of the CONFIG, like:
    __CONFIG _INTRC_OSC_NOCLKOUT &_WDT_OFF & _LVP_OFF & _CP_OFF
    Aug 2009
    Paso Robles California
    are you using mplab ?
    I also had problems with the config
    did you comment out in the config file?
    sorry for the crappy answers but I have been away from PBP for quite a while.
    in mplab you can set up the config file manually
    or you could do what HenrikOlsson
    said and fix the problem good catch
    Jun 2011
    That was the problem!
    I understand syntax is always something important to consider and can deal with UC and LC, commas, and other punctuation, but putting two underscores (__) together as a lead qualifier is really dumb, I think. Talk about ambiguity. Couldn't MeLabs have used a more obvious element like the @ symbol, or the #, or even only ONE underscore? (I don't use C and Pascal because of the syntax rules.)
    Sorry don't mean to gripe but a little issue like that had me tied up for 2 hours trying to research the issue before asking for some help. Thanks Henrik.
    You can bet I won't have this error again!
    I'm glad you got it going!
    In this case I don't think it's fair to blame MELABS though. The #CONFIG tells PBP to pass what ever is between it and the #ENDCONFIG directly to the assembler instead of the default configuration for the particular device you're compiling for. So, it's really the MPASM syntax and therefor Microchip you should blame ;-)
    Apart from that I agree, questions/problems regarding the configs are very common around here. MELABS actually made A LOT better when introducing the #CONFIG / #ENDCONFIG directive since you no longer have to edit the default, stock include files for the device.
    Finally, if you look in the Device_Reference folder in you PBP3 folder you'll find a file for each device, it contains all the CONFIG options for that particular device.
    Jun 2011
    You're correct, it isn't MeLabs "fault" since it is Microchip's assembler. I'm sure they had a reason for putting in the two underscores.
    I love MeLab. They have a great product and super service, especially from Darrel Taylor. I have convinced two of my buddies to buy the MeLab development system, that's how much I believe in the product.
    I did more reading, including the MPASM assembler manual and now ALL OVER THE PLACE I read about the "double-underscore"!
    Thanks again.
