Can an asm interrupt contain gosub to a picbasic routine?
Results 1 to 6 of 6
    Feb 2005
    Kolkata-India
    Default Could you explain a little bit more
    Hi Joe,
    Thanks for the reply. In your asm ISR I find that you clear the int flag defined not by PICBASIC. You are directly handling a RAM location defined earlier by you. Another thing that is unclear to me is that when PBP defines a word does it put the higher and lower byte in consecutive location and in the same bank. I am not confident in handling RAM bank switching. Although I am trying to get familiar. I successfully called (a.k.a. call)a picbasic subroutine from within an asm ISR routine to test conditions and take action. I got the idea from the asm file generated by PBP where a sub-routine ends with the "return" statement. (The same for assembly too). My application is time sensitive and I do a little bit multitasking.(I seggregate jobs in different time frame). For example I generate an int. every mili second. Count the mili second to 9 (for e.g.) and use a select case within the main body to do different things at different time. Your and others thoughts on this regards is most most welcome.
    Sougata
    Feb 2003
    Delaware
    Default Bank option and clarification.
    I use the BANK option when declaring variables to ensure that the entire variable is in a known bank. Here is a sample.
    'Variables
    aflag   var     byte            'individual bits are used as flags.
    bflag   var     byte    BANK0'individual bits are used as flags.
    cflag   var     byte        ' individual bits are used as flags.
    adval2  var     word        'Value of pot on AN2
    adval3  var     word        'Value of pot on AN3
    i       var     word    BANK0'general purpose variable
    pc      var     word    BANK0        'pack counter
    TMR0CNT var     word    BANK0        'number of times TMR0 has overflowed. used to update AD and LCD.
    delay   var     word        'how long we wait to fire valve.
    bc      var     word        'bad count.  how many bad barcodes scanned
    pct     var     word        'the percentage of bad scans to packages.
    As for clearing the interrupt, I am using assembly language to do that.
      BCF 0x0B,2              ;CLEAR INT FLAG
    The BCF command is bit clear and 0B is the register that contains the interrupt while the ",2" is the actual bit. I clear the interrupt in the ISR so that there is no chance that it will cause a false trip by being read twice.
    Please also look at how I set up registers and define aliases to register bits.
    	ADCON1 = %10000111	' Set PORTA and PORTE digital and right justify result
        TRISA = %11101100	'
    	TRISB = %11111001
        TRISC = %10001000
        OPTION_REG = %10100100	' Set which edge RB0 int on (falling set).
        INTCON  =   %11110000       ' Enable interrupt for Timer0 AND peripherals
        PIE1    =   %00100001   'Allow Timer1 & serial in to cause a periheral interrupt.
        T1CON   =   %00000000   'Set Timer1 prescaler to 1
    'Aliases for registers
    INTF        VAR     INTCON.1	' Alias INTF (RB0/INT external interrupt flag) This is RTS!!!
    TMR0_EN     VAR     OPTION_REG.5' CLEAR TO START TIMER0 SET TO STOP.
    TMR0IF      VAR     INTCON.2    ' TIMER0 INTERRUPT FLAG BIT.
    TMR1_ON     VAR     T1CON.0     ' SET TO START TIIMER1 CLEAR TO STOP
    TMR1IF      VAR     PIR1.0      ' TIMER1 INTERRUPT FLAG
    RCIF        VAR	    PIR1.5		' Alias RCIF (USART Receive Interrupt Flag)
    OERR        VAR	    RCSTA.1		' Alias OERR (USART Overrun Error Flag)
    CREN        VAR	    RCSTA.4		' Alias CREN (USART Continuous Receive Enable)
    I hope this is helpful. It really isn't that difficult to increment a variable in assemble that is what my original post showed with the TMR0CNT. I know that you can call a basic subroutine from inside your ISR but I question whether it defeats the purpose of the ISR. Perhaps not but I like to keep my interrupts as short as possible.
    Have you considered turning off the interrupts and polling the interrupt bit. Do this in your basic loop and if it is set, clear it and increment your counters. If the loop is small enough you should be able to this almost as quickly as with an iterrupt. Just a thought as this will make for some simple code.
    Joe
    Feb 2005
    Kolkata-India
    Default Thanks Joe
    Hi Joe,
    Thanks for the post. It is really helpful and I beleive it will be useful to other forum members greatly. Thanks again
    Sougata
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  3. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 00:36
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 01:02
