Voltage Ref Problem
Results 1 to 6 of 6
    Sep 2005
    Campbell, CA
    Default Re: Voltage Ref Problem
    Are VA and VA1 WORD variables?
    Charles Linquist
    Puerto Rico
    'For global reference to system voltage, use the Voltage variable, which is based on a
    'scale of 1 to 1000, with 775 = 7.75 volts. Remember that the resistors on the board
    'divide the actual battery voltage in half so the ADC can "digest" it without damage.
    'ADCIN voltages are limited to 5. Both EGT and Voltage are compared with the onboard
    'precision voltage reference which delivers a perfect 5V.
    '**Voltage**
    LCDVLow=0
    LCDVHigh=0
    Voltage=0
    ADCIN VoltChannel, Voltage 'Take just 1 voltage sample. 7.6V = 194
    ' SerOut LCDScreen, T9600, [LCDCmd, LCDLine1,"VoltsX=",#Voltage] 'RPM
    ' PAUSE 2000
    Voltage = Voltage * 4 '194 * 4 = 776
    LCDVHigh = Voltage / 100 '776 / 100 rounds to 7
    LCDVLow = (Voltage // 100) / 10 '776 // 100 = 76, 76 / 10 = 7
    LCDVLow = LCDVLow - 2
    'Final Display = 7.7
    My Hobbies is PicBasic PRO
