Error 238 Preprocessor Directive Expected ???
Results 1 to 2 of 2
    Alabama,USA
    Default Error 238 Preprocessor Directive Expected ???
    I have never encountered this error before. I have gotten this error on two short test programs. The list of compiler error codes located in the Wiki does not give an explanation for this error code. Anyone have an idea what this means? I'm not using a preprocessor nor do I reference any processor other than a 16F873A. ???
    Alabama,USA
    Default Re: Error 238 Preprocessor Directive Expected ???
    Problem found!
    While using Typcasting Variables inside of Arrays, a variable name in ASM did not match the variable name in the EXT statement.
    Array VAR BYTE[8]
    Dog = Array
    Cat# = Array+1
    Dog VAR BYTE EXT
    Cat VAR BYTE EXT * the # in the ASM Cat# caused error 238
    Issue Closed!
