I2C help Please
Results 1 to 7 of 7
Thread: I2C help Please
    Dec 2011
    Default I2C help Please
    I am trying to get a 16F887 to communicate with the LCD backpack from web4robot working over I2C and can not for the life of me figure it out. This is my first go at I2C and have been working on it for the past few days. Please take a look at my code and point me in the right direction. Both the data and clock pin seems to be stuck high.
          'COMMANDS
    'Prefix Command Parameter Description
    '$FE    $00    null      No operation
    '$FE    $01    1 Byte    Changing the I2C Slave Address
    '$FE    $02    1 Byte    Changing BAUD Rate
    '$FE    $03    1 Byte    Set Backlight Brightness
    '$FE    $04    1 Byte    Set Contrast
    '$FE    $05    None      Save Splash/Startup Screen
    '$FE    $06    None      Display Firmware Version Number
    '$FE    $07    None      Display Serial Baud Rate
    '$FE    $08    None      Display I2C Address
    '$FE    $09    Null      No operation
    '$FE    $0A    None      Turn ON Display
    '$FE    $0B    None      Turn Off Display
    '$FE    $0C    2 bytes   Set Cursor Position
    '$FE    $0D    None      HOME Cursor
    '$FE    $0E    None      Turn ON Underline Cursor
    '$FE    $0F    None      Turn Off Underline Cursor
    '$FE    $10    None      Move Cursor Left One Space
    '$FE    $11    None      Move Cursor Right One Space
    '$FE    $12    None      Turn ON Blinking Cursor
    '$FE    $13    None      Turn Off Blinking Cursor
    '$FE    $14    None      Clear Screen
    '$FE    $15    Variable  Print String
    '$FE    $16    1 Byte    Init Horizontal Bar Graph
    '$FE    $17    4 bytes   Draw Horizontal Bar Graph
    '$FE    $18    None      Init Vertical Bar Graph
    '$FE    $19    4 bytes   Draw Vertical Bar Graph
    '$FE    $1A    9 bytes   Load Custom Characters
    '$FE    $1B    None      READ Keypad
    Include "modedefs.bas"
    OSCCON = %01110001          'Int CLK 8MHz
    ANSEL = 0
    ANSELH = 0           'All digital
    ADCON1 = 7
    DEFINE OSC 8                '8MHz
            TRISA = %00000000
            TRISB = %00000000
            TRISC = %00000000
            TRISD = %00000000
            TRISE = %000
     CPIN var PortC.3
     DPIN var PortC.4
     'ADDRESS = $4C
     pause 2000 ' lcd start up
    i2cwritE DPIN, CPIN, $4C,[$FE, $04, 99],NOACK  'Sets contrast (0-100)
    PAUSE 100
    i2cwritE DPIN, CPIN, $4C,[$FE, $03, 200], NOACK 'Sets the brightness (0-250)
    PAUSE 200
    i2cwritE DPIN, CPIN, $4C,["Hello World!"], NOACK    'text sent to the LCD, defaults to row 0, col 0
    PAUSE 1500
    'Next is to make sure all of above worked
      HIGH PORTD.2
      PAUSE 250
      LOW PORTD.2
      PAUSE 250
      HIGH PORTD.2
      PAUSE 250
      LOW PORTD.2
      PAUSE 250
      HIGH PORTD.2
      PAUSE 250
      LOW PORTD.2
      PAUSE 250
      HIGH PORTD.2
      PAUSE 250
      LOW PORTD.2
    NOACK:
        HIGH PORTD.2
        PAUSE 5000
        LOW PORTD.2
        PAUSE 1000
    Nov 2007
    West Covina, CA
    Default Re: I2C help Please
    I can't see why you don't get at least something out of the data and clock pins, these normally idle High anyways. Watch it with a scope if available.
    Does your program go to NOACK every time? The "END" after it will cause it to stop right there. Put a GOTO Main instead.
    I would also structure your program something like this:
    Configs
    I2CWRITE DPIN, CPIN, $4C, [$FE,$14], NOACK   ' Clears screen
    PAUSE 1500 'Next is to make sure all of above worked
    HIGH PORTD.2   PAUSE 250
    LOW PORTD.2   PAUSE 250
    LOW PORTD.2 goto main
    NOACK:
    HIGH PORTD.2
    PAUSE 5000
    LOW PORTD.2
    PAUSE 1000
    GOTO Main       ' Start over
    The LCD contrast and brightness only needs to be set up once before the Main loop unless you want to get fancy but save that till later.
    Verify the Address $4C is correct otherwise all your attempts to write to the LCD will be ignored.
    Last edited by LinkMTech; - 27th December 2011 at 16:10. Reason: fixed some confusing typos
    Louie
    Nov 2007
    West Covina, CA
    Just one more thing, as Columbo would say.
    Here's some scope shots I documented that might help.
    I2CWrite Data Screen Shots.pdf
    Louie
    Dec 2011
    The program does not go to NOACK at all, thats why i put the END in there to stop the program just to make sure. I can unplug the the I2C lcd controller and the led still blinks all the time. I do not have a scope. As far as the contrast and brightness, I just threw them in there but thanks for pointing it out. SCL and SDA lines are pulled high with a 4.7K resistor.
    Nov 2007
    West Covina, CA
    Ahhh! I just checked out one of my programs and noticed that all the data had to be sent by their ASCII value.
    Instead of:
    I2CWRITE DPIN, CPIN, $4C, ["Hello"], NOACK
    Send it:
    I2CWRITE DPIN, CPIN, $4C, [$48,$65,$6C,$6C,$6F], NOACK  ' Using HEX values
    or
    I2CWRITE DPIN, CPIN, $4C, [72,101,108,108,111], NOACK  ' Using DEC values
    My contrast and brightness values were also set a lot lower: Contrast= $1C or 28 and Brightness= $6 on a Newhaven serial display.
    Louie
    Dec 2011
    I finally got the thing working!!! I realized that the address I was using $4C was only 7bits long, tried $98 for the address and it started working. Been working on this for about 5 days now, guess the important thing is that its working and I can now start my project as everything revolves around this lcd controller.
    Thanks LinkMTech for all your input!!!!
    SDA var PORTC.4
    SCL var PORTC.3
    I2CWRITE SDA,SCL,$98, ["HELLO"]
    Nov 2007
    West Covina, CA
    Awesome!
    Best of luck on the rest of your project!
    Louie
