Re: Sparks?
Results 1 to 1 of 1
Thread: Re: Sparks?
    Jul 2005
    Midwest
    Default Re: Sparks?
    Hi Everyone, I hope the Holidays have been good to you!
    I have a project involving a 18F252 which uses a linear 5 volt regulator (LM2936). I've quite a bit of capacitance hanging off the 5 volt output (mostly IC bypass caps, a couple 10 uf tantalum's etc). When I apply power to the board there is a small spark when I touch the power supply wires together. The regulator input only has a 0.1 uf cap, so I'm thinking I must be getting a significant current rush from the regulator output?
    What if anything should I do about this? Putting a 10 ohm resistor in series with the power supply lead (12 vdc) seems to remove the spark.
    Oops, I may need a nap soon. I also have a switched 5 vdc regulator for powering peripherals. This regulator has a 10 uf cap on the input. This guy must be the culprit....I'll check it out tomorrow.
