Making a flying star effect with LEDs
Results 1 to 23 of 23
    May 2009
    Montreal, QC, Canada
    Default Re: Making a flying star effect with LEDs
    I played with the settings and the LED is now dimming.
    I am now facing my first issue... how to produce the effect I want.
    I will try to find more examples, there's lots of scrolling text but so far I found nothing that resemble what I'm trying to do.
    If anyone have a link feel free to share.
    Mike
    Jan 2006
    Istanbul
    Default Matrix LED example 64 LED.
    Try this one.
    Pot changes index value for test purposes.
    You can have 64 LEDs with this example.
    LED corresponding to Index value will turn on.
    Playing with this code, you can drive PORTB pins via MIBAM and have lots of effects.
    @ __config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _BODEN_OFF & _LVP_OFF & _CP_ALL
    CLEAR
    DEFINE OSC 20
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE ADC_BITS 8      ' Set number of bits in result
    DEFINE ADC_CLOCK 3     ' Set clock source (rc = 3)
    CMCON = 7              ' Disable Comparator & VRef. etc.
    pauseus 10
    CVRCON = 0
    ADCON1 = 96 ' 100000    Set analog thingie.
    ADCON0 = 0              ' All analog, we just need RA0.
    TRISA = 255             ' PORTA all input. Others output.
    TRISB = 0
    TRISC = 0
    TRISD = 0
    X var PORTB
    Y var PORTC
    Index var byte
    Index2 var byte
    OldVal var byte
    Pause 10
    Begin:
        lcdout $fe,1,"Matrix Test"
        X = 0
        Y = 255
        index = 0
        oldval = 255
    Start:
        adcin 0, index      ' Index = max 255.
        index = index / 4   ' To get index values between 0 to 63.
        if oldval <> index then ' Act only when the number changes.
            index2 = index/8    ' X scans 8 bits.
            x = 0               ' turn it Off.
            x.0[index2] = 1     ' Set the bit in line.
            y = 255             ' turn all pins on (output is off).
            lookup index2,[7,15,23,31,39,47,55,63],index2   ' Get matrix line.
            y.0[index2-index] = 0                           ' Clear the bit in line (output is on)
            lcdout $fe,$c0,dec3 index , " ",dec3 index2
            pause 10
            oldval = index
        goto start
    Last edited by sayzer; - 24th December 2011 at 17:07. Reason: percent sign does not show up in code block.
    May 2009
    Default Re: Matrix LED example 64 LED.
    I will give this a try.
    which PIC are you using? I can't read the text in the picture.
    You are using one resistor per column, is it right to say that no matter what, there is only one LED ON at a time?
    Thank you for the example, this will help a lot.
    Mike
    Jan 2006
    Istanbul
    The example is for 16F877A.
    In the example, yes, there is only one LED at a time.
    May 2009
    (Post removed at user's request in next post)
    May 2009
    I would have liked to delete thread #18 because that issue was resolved, I was missing some piece of code for MIBAM.
    Anyways, I started off using Sayzer's code, then I was able to bypass the POT and make the LEDs scan automaticly.
    I then added the MIBAM code (with no apparent difference) and I am still back to square one; I am not able to have about 20 LEDs on at the same time (or appear to be) to produce an effect similar as the video in thread #11
    I am obviously not getting it and I would appreciate some guidance.
    Below is the code I have so far, it is turning on then off LED1 to LED64 at the right speed but I am trying to turn on LED1, LED2...LED20 and from there when LED21 turns on the LED1 will turn off, LED22 on - LED2 off and so on.
    @ __config _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_OFF & _BOREN_OFF & _LVP_OFF & _CP_OFF
    CLEAR
    DEFINE OSC 20
    BAM_COUNT CON 8
    INCLUDE "MIBAM.pbp"
    ;____[ For 12F/16F only - Interrupt Context save locations]_________________
    wsave  var byte    $20     SYSTEM  ' location for W if in bank0
    ;wsave  var byte    $70     SYSTEM  ' Alternate save location for W
                                        ' if using $70, comment out wsave1-3
    ;       Comment them out to fix the problem ----
    ; -- The chip being used determines which variables are needed -------------
    wsave1 VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2 VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    wsave3 VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    ;---DO NOT change these-----------------------------------------------------
    ssave  VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave  VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    CM1CON0 = 0
    CM2CON0 = 0
    pauseus 10
    ADCON1 = 0
    TRISB = 0
    TRISC = 0
    TRISD = 0
    test var byte
    X var PORTB
    Y var PORTC
    x = 0   ; make sure all LEDs are off
    y = 0   ; when powr is applied
    I var byte
    Index var byte
    Index2 var byte
    OldVal var byte
    Pause 10
    BAM_LIST  macro           ; Define PIN's to use for BAM
     BAM_PIN (PORTB,0, X)     ;   and the associated Duty variables
     BAM_PIN (PORTB,1, X)
     BAM_PIN (PORTB,2, X)
     BAM_PIN (PORTB,3, X)
     BAM_PIN (PORTB,4, X)
     BAM_PIN (PORTB,5, X)
     BAM_PIN (PORTB,6, X)
     BAM_PIN (PORTB,7, X)
     BAM_INIT  BAM_LIST        ; Initialize the Pins
    ENDASM                 ' Mirror Image BAM module
    Begin:
        ;lcdout $fe,1,"Matrix Test"
        ;PAUSE 500
        X = 0
        Y = 255
        index = 0
        oldval = 255
    Start:
    ;    adcin 0, index      ' Index = max 255.
    for i = 0 to 255
        index = i / 4   ' To get index values between 0 to 63.
        ;if oldval <> index then ' Act only when the number changes.
            ;lcdout $fe,$c0,dec3 index , " ",dec3 index2
            ;pause 10
            oldval = index
        ;endif
         pause 1
     next i
        goto start
    May 2009
    I am still struggling with this, however I am a few steps further (I hope)
    First off I played with Darrel's Cylon/Kitt code
    and slightly modified it to scan one way but I have 2 issues;
    • Since I have 64 LEDs connected like Sayzer indicated I get 8 LEDs turned on and slowly drained at the same time.
    • After each scan I could not pause until the last LEDs fully extinguish and have an extra 2 seconds before the next scan starts.
    This is the modified code:
    CLEAR
    ;-- 16F887 Internal OSC @ 8Mhz ------
    ;@  __config _CONFIG1, _INTOSCIO & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    @ __config _CONFIG1,  _INTOSCIO & _WDT_OFF & _MCLRE_OFF & _LVP_OFF & _CP_OFF & _BOREN_OFF
    ANSEL = 0
    ANSELH = 0
    OSCCON = %01110001
    DEFINE OSC 8
    TRISC = 0       ; I needed to clear PORTC
    Y var PORTC
    y = 0
    ' --- IF any of these next three lines cause an error ?? -------------------
    ' -- The chip being used determines which variables are needed -------------
    '---DO NOT change these-----------------------------------------------------
    ;----[ MIBAM Setup ]--------------------------------------------------------
    ;BAM_FREQ  CON 100                   ; Desired Refresh rate Limit
    ;ScopeSync VAR PORTB.0               ; if declared, generates sync for OScope
    ;DEFINE BAM_INFO 1                   ; use to display MIBAM results
    BAM_COUNT CON 8                     ; How many BAM Pins are used?
    INCLUDE "MIBAM.pbp"                 ; Bit Angle Modulation module
    BAM_DUTY  VAR BYTE[BAM_COUNT]
      LED1    VAR BAM_DUTY[0]           ; group them in an array for easy access
      LED2    VAR BAM_DUTY[1]           ; with FOR loops etc.
      LED3    VAR BAM_DUTY[2]
      LED4    VAR BAM_DUTY[3]
      LED5    VAR BAM_DUTY[4]
      LED6    VAR BAM_DUTY[5]
      LED7    VAR BAM_DUTY[6]
      LED8    VAR BAM_DUTY[7]
         BAM_PIN (PORTB,0, LED1)        ;   and the associated Duty variables
         BAM_PIN (PORTB,1, LED2)
         BAM_PIN (PORTB,2, LED3)
         BAM_PIN (PORTB,3, LED4)
         BAM_PIN (PORTB,4, LED5)
         BAM_PIN (PORTB,5, LED6)
         BAM_PIN (PORTB,6, LED7)
         BAM_PIN (PORTB,7, LED8)
    ;_________________________________________________
    Speed       CON 5         ; Smaller = Faster
    TracerSpeed CON 20        ; Smaller = Faster Left/Right
    Brightness  CON 200       ; Tracers DutyCycle
    DrainSpeed  CON 40        ; Smaller = Shorter Trail
    Idx         VAR BYTE
    LoopCount   VAR BYTE
    NextLED     VAR BYTE
    TraceDIR    VAR BIT
      TraceDIR  = 0
      LoopCount = 0
      NextLED   = 0
        if LoopCount = TracerSpeed then             ; __[ Cylon/Kitt Scanner ]__
          LoopCount = 0
          BAM_DUTY(NextLED) = Brightness
      ;    if TraceDIR then                          ; if scanning left
      ;      NextLED = NextLED - 1
      ;      if NextLED = 0 then TraceDIR = 0
      ;    else                                      ; else scanning right
            NextLED = NextLED + 1
      ;      if NextLED = BAM_COUNT-1 then TraceDIR = 1
      ;    endif
        FOR Idx = 0 to BAM_COUNT - 1                ; Drain all dutycycles
           IF BAM_DUTY(Idx) > 0 then
               BAM_DUTY(Idx) = BAM_DUTY(Idx)*DrainSpeed/(DrainSpeed+1)
        NEXT Idx
        pause Speed
        if NextLED = BAM_COUNT then NextLED = 0     ; Added this line
        LoopCount = LoopCount + 1
    GOTO Main
    Also looking at Sayzer's code example, I removed the ADC, the LCD and modified based on my understanding and came up with this result which is scanning at the proper rate and the pause between scans.
    CLEAR
    ANSEL = 0
    ANSELH = 0
    OSCCON = %01110001
    DEFINE OSC 8
    TRISB = 0
    TRISC = 0
    TRISD = 0
    X       var PORTB
    Y       var PORTC
    xCOL    var byte
    yROW    VAR BYTE
    Speed   var word
    Pause 10
    Begin:
        X = 0
        Y = 255
        speed = 30
    Start:
        for xcol = 0 to 7
            x = 0
            x.0[xcol] = 1
            for yrow =7 to 0 step -1
                y = 255
                y.0[yrow] = 0
                pause speed
            Next yrow
        next xcol
        y = 255         ; turn off (and drain all LEDs)
        PAUSE 2000      ; wait before starting over
    goto start
    Last but not least I am trying to find a way to add a trail of 20 to 30 LEDs with the same effect as Darrel's code using MIBAM.
    I can't figure it out
    Mike
