16f648 + Bluetooth USB dongle
Results 1 to 2 of 2
    Mar 2004
    Rather than trying to interface a usb dongle to your project it may be easier to use a dedicated bluetooth chip as these will give you serial data and do the majority of the hard work.
    I don't have any code but here is a datasheet for such a chip.
    http://amx.co.uk/bluetooth.pdf
    You basically need the chip an antenna (they make surface mount versions) and the rest seems straight forward.
    Look around page 24 for interfacing info. I came across a Toshiba chip which only had 8pins which is a bit more managable but I couldn't find an english datasheet.
    If you are in a real hurry you can buy rs232 BT dongles
    http://www.psism.com/cs0400.htm
    Rob
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. USB bluetooth interface to PIC
    By naidab in forum Bluetooth
    Last Post: - 17th March 2007, 23:37
  4. PIC to Bluetooth via USB
    By InitialDriveGTR in forum General
    Last Post: - 6th March 2006, 06:56
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
