I need help on ADC interrupt
Results 1 to 6 of 6
    Jun 2011
    Philippines
    Default Re: I need help on ADC interrupt
    Hi macrackit,
    Sorry for that my mistake...here is the whole code, I'm using Pic16F877A with 20mhz crystal
    clear
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    pause 4000
    '@ DEVICE HS_OSC
    DEFINE   OSC 20
    Define ADC_BITS     8   ' Set number of bits in result
    Define ADC_CLOCK    3   ' Set clock source (3=rc)
    Define ADC_SAMPLEUS 50  ' Set sampling time in uS
    adval1 Var Byte          ' Create adval to store result
    adval2 Var Byte
    adval3 Var Byte
    TRISA = 111111    ' Set PORTA to all input
    ADCON1 = 000010   ' Set PORTA analog
    TRISC  = 000000    ' PORTC.7 is the RX input, PORTC.6 is the TX output
    TRISD  = 000000
    led0       var     PORTD.0
    led1       var     PORTD.1
     ' The following codes is for bluetooth------------------------------------------------------------------------------------
     SerOut2 PortC.6,84, [$02,$52,$27,$06,$00,$7F,$12,$13,$23,$17,$09,$00,$03]
     pause 200
     SerOut2 PortC.6,84, [$02,$52,$66,$00,$00,$B8,$03]
     pause 200
     Serout2 PortC.6,84, [$02,$52,$04,$11,$00,$67,$10,$4D,$49,$43,$52,$4F,$42,$4F,$58,$42,$54,$31,$20,$20,$20,$20,$00,$03]
     RX var byte ' Receive byte
    mainloop:
       ADCIN 0, adval1       ' Read channel 0 to adval1
       ADCIN 1, adval2       ' Read channel 1 to adval2
       pause 20
       Pause 100            ' Wait .1 second
       if adval1 >25 then
       SerOut2 PortC.6,84, ["1"]    ' sends 1 to Bluetooth TX
       Serout PortD.2,T9600, [$1B,$45,"[1] ",#adval1]   ' Displays to serial LCD for debugging
       Pause 100
       Endif
       if adval2 >25 then
       SerOut2 PortC.6,84, ["2"]   ' sends 2 to Bluetooth TX
       Serout PortD.2,T9600, [$1B,$45,"[2] ",#adval2]   ' Displays to serial LCD for debugging
       Pause 100
       Endif
       Goto mainloop        ' Do it forever
    My problem is how to receive incoming data from bluetooth with SERIN without freezing the application..
    regards,
    tacbanon
    Jun 2011
    Philippines
    I'm trying to play with this code from Mister_e, but my trouble is I can not send message to PC at the same time(Sending Hello and reading from analog pin). I hope anyone can give a hint on this.
        '   Simple program to handle USART interrupt using PIC16F877 @20MHZ
        '   This program will Blink a LED on PORTB.0 to show
        '   that the PIC is running.
        '   This program also allow the user to activate or deactivate
        '   a LED connected on PORTB.1 pin by sending command from a PC
        '   terminal software using 9600,n,8,1 setting
        '   User command:
        '                1. If character "1" is received => enable the LED1
        '                2. if character "2" is received => disable the LED1
        '                3. If character "3" is received => enable the LED2
        '                4. if character "4" is received => disable the LED2
        'DEFINE LOADER_USED 1        ' using bootloader
        Include "modedefs.bas"
        DEFINE OSC 20               ' running at 20 MHZ
        '    PORT setting
             TRISC=%10000000        ' RC.7 => USART RX pin set to input
                                    ' all other pin set to output
             TRISB=0                ' RB<7:0> set to output
        '    USART setting
             ' Since we will not use HSERIN/HSEROUT, we must
             ' write directly to internal PIC register
             TXSTA=$24              ' enable transmit and SPBRGH=1
             RCSTA=$90              ' Enable USART and continuous receive
             SPBRG=129           ' BAUD RATE = 9600 BAUDS
        '    Interrupt definition
             PIE1.5   =1            ' enable USART receive interrupt
             INTCON.6 =1            ' enable peripheral interrupt
        '    Alias definition
             RCIF      var PIR1.5   ' receiver interrupt
             StatusLED var PORTB.0  ' the LED who show a 'running process'
             UserLED1   var PORTB.1  ' the LED1 that user want to control
             UserLED2   var PORTB.2  ' the LED2 that user want to control
             UserLED3   var PORTB.3  ' the LED3 that user want to control
             UserLED4   var PORTB.4  ' the LED4 that user want to control
        '    Variable definition
             Delay     var word     '
             DataIn    var byte     ' use to store RCREG content
             Discard   var byte     ' use to erase RCREG register
        '    Hardware/software initialisation
             PORTB=0                ' clear PORTB
             on interrupt goto USARTInterrupt
    DEFINE ADC_BITS 8       ' Set A/D for 8-bit operation
    DEFINE ADC_CLOCK 1      ' Set A/D clock Fosc/8
    DEFINE ADC_SAMPLEUS 50  ' Set A/D sampling time @ 50 uS
    adval Var Byte          ' Create adval to store result
    TRISA = %11111111    ' Set PORTA to all input
    'ADCON1 = %00000011  ' Set PORTA.0,1,2,5 = A/D, PortA.3 = +Vref
    ADCON1 = %00000010   ' Set PORTA analog
    Start:
        '    Main program loop that make the user happy to
        '    see a LED flashing to mean that something is
        '    running
        Serout2 PortC.6, 84,["Hello",13]
        toggle statusled
        'for delay = 1 to 5000       ' use a loop delay to ensure
          'pauseus 5                 ' getting interrupt as fast as possible
          'next
        ADCIN 0, adval
        Serout2 PORTC.6, 84, ["Value: ", DEC adval, 13, 10] ' Display value
        goto start
    disable interrupt
    USARTInterrupt:
        '    Here's the interrupt routine who will make the user
        '    much happy by giving him the feeling to have the
        '    control on the machine when the status of the user
        '    LED will change
        RCSTA=0                     ' Disable serial port AND
                                    ' clear possible error (FERR,OERR)
        datain=RCREG                ' Get data
        while RCif                  ' wait untill the RCREG is empty
              discard=RCREG         ' by reading it and store result in a
        wend                        ' don't care variable
        select case datain          ' What to do with that data???
               case "1"            ' User selection = 1
                    userled1=1       '      => Enable the LED
               case "2"           ' User selection =2
                    userled1=0       '      => disable the LED
               case "3"            ' User selection = 3
                    userled2=1       '      => Enable the LED
               case "4"           ' User selection =4
                    userled2=0       '      => disable the LED
               case "5"            ' User selection = 3
                    userled3=1       '      => Enable the LED
               case "6"           ' User selection =4
                    userled3=0       '      => disable the LED
               case "7"            ' User selection = 3
                    userled4=1       '      => Enable the LED
               case "8"           ' User selection =4
                    userled4=0       '      => disable the LED
               end select
        RCSTA=$90                   ' Re-enable the serial PORT AND
        resume                      ' get out of here
    enable interrupt
    Hardware: Pic16F877A at 20Mhz crystal
    regards,
    tacbanon
    Jun 2011
    Philippines
    I managed to send message to PC and added sensor reading(working in a separate program), but now I have strange reading on my temperature and light sensors. kindly check my code.
        '    PORT setting
        '    USART setting
        '    Alias definition
             Delay     var word     '
    'ADCON1 = %00000010   ' Set PORTA analog
    '--------Variables--------------------------------------------------------------
    light var WORD
    samples VAR WORD        ' Multiple A/D sample accumulator
    sample  VAR BYTE        ' Holds number of samples to take
    temp    VAR BYTE        ' Temperature storage
    samples = 0             ' Clear samples accumulator on power-up
    samples2 var word
    sample2  VAR BYTE
    samples2 = 0
    Start:
        '    running
        toggle statusled
        Pause 100
        FOR sample = 1 TO 20    ' Take 20 samples
            ADCIN 1, temp       ' Read channel 0 into temp variable
            samples = samples + temp ' Accumulate 20 samples
            PAUSE 100           ' Wait approximately 1/4 seconds per loop
        NEXT sample
        temp = (samples/20)
        Hserout ["Temp=",DEC temp ,"'C" ,13]
        ADCIN 0, light
        Hserout ["Light=",DEC light ,13]
        goto start
    disable interrupt
    USARTInterrupt:
        '    LED will change
               end select
    enable interrupt
    regards,
    tacbanon
    Jun 2011
    Philippines
    I finally got the code to work, the problem was faulty circuitry, sorry for not double checking on my part before posting...Thank God for this forum and everyone here who I believed to be my PICexperts(macrackit, Mr_e, DT, Skimask, Henrick just to name a few) heroes...
    Merry Christmas everyone!!!!
    regards,
    Tacbanon
