Serin2,Serout2,Wait problem
Results 1 to 17 of 17
    Default Re: Serin2,Serout2,Wait problem
    Charles, thanks I will give that a go when I get back. I am on the road for the next four days.
    One other thing I was thinking about today flying from CO to PA...First off here is what I am doing. I am controlling electric motors on a agriculture planter. Each row has an electric motor. For each four rows I have one control box. In the tractor I have a board and touchscreen. The tractor board can be called the master board. It sends the required motor speed to each board for each rows motor. The planter boards then take the speed, do the PID and then report back to the master the row speed.
    The thing I was thinking about was right now I have the master sending out data to each board separately. I was wondering if it would be better if it sent out one data packet that had Control Box ID and the four speeds for every control box within one data stream. So for example I have a 16 row planter. There are four control boxes talking back and forth to the master/tractor board. The master sends out four different packets. Each with Control Box ID and the four row speeds. So all four boards are getting data, only one is doing something with it. The other three are waiting for their data. I am wondering if there would be any drawbacks to send out one packet that would be like this
    Box1, Speed1, Speed2, Speed3, Speed4,Box2, Speed5, Speed6, Speed7, Speed8,Box3, Speed9, Speed10, Speed11, Speed12,
    Box4, Speed13, Speed14, Speed15, Speed16,
    Then the tractor only has to take time to send out one data pack and each control box gets speed data every time the tractor sends out data, no waiting for its own data.
    Are there any drawbacks to sending longer data streams?
    Sep 2005
    Campbell, CA
    I think that the "large packet" idea has no drawbacks, and is easier to maintain and code. By the way, I grew up on a farm in southwest Iowa and got my EE degree at Iowa State.
    Charles Linquist
    you will be able to appreciate this then, here is my site
    www.grahamelectricplanter.com
    Quote Originally Posted by Charles Linquis View Post
    I have 6 PICs chattering amongst themselves in a gas mixer. The comms is cable based, not wireless, but there are similarities. I found I had to send a number of preamble characters to get the receivers reliably synchronised. The number of preamble characters and the value of the character need to be chosen with some care in an attempt to get a 'balanced' signal on the line. Sending four $AA or $55 characters then "$" as a 'start of message' works a treat for me.
    /code:
    Snip from RxPacket:
    GetSoM:
    serin2 msg, 84, 250, rxpacketdone, [wait ("$")]
    GetPktInfo:
    for C_A = 0 to 1
    serin2 msg, 84, [rxchar[C_A]]
    chksum = chksum + rxchar[C_A]
    next C_A
    pkttype = rxchar[0] : msglen = rxchar[1]
    GetPayLoad:
    for C_A = 2 to (msglen + 1)
    next C_A
    GetEoMandChkSum:
    for C_A = 2 to 3
    serin2 msg, 84, [rxchar[msglen + C_A]]
    next C_A
    BadMsgCheck:
    if rxchar[msglen + 2] <> "*" then getmessage 'should be EoM.
    if rxchar[msglen + 3] <> chksum then getmessage 'try again
    Snip from TxPacket:
    'Send PreAmble
    chksum = 0
    for C_A = 1 to precnt
    serout2 msg, 84,[preambl]
    next C_A
    'Send Start of Message
    serout2 msg, 84,["$"]
    'Send message and accumulate ChkSum
    for C_A = 0 to (msglen + 1)
    serout2 msg, 84, [txchar[C_A]]
    chksum = chksum + txchar[C_A]
    next C_A
    'Send EoM and ChkSum
    txchar[msglen+2] = "*" : txchar[msglen+3] = chksum
    serout2 msg, 84, [txchar[msglen+2], txchar[msglen+3]]
    pause 5 'time enough for recipient to let go of Ack line
    if ack = 0 then sendmessage 'recipient is requesting a repeat
    TxPacketDone:
    'Message sent or timed out so release CommsBus
    TRISB = %11111111
    /endcode
    HTH
    BrianT
    Charles
    I am playing around with HSERIN and not having much luck. I am pretty sure I have sorted out the problem and I am hosed for making HSERIN work on this board. WHen I use DEDBUGIN here is the setup info
    DEFINE DEBUGIN_REG PORTC
    DEFINE DEBUGIN_BIT 7
    DEFINE DEBUGIN_MODE 1 ' 1 = inverted, 0 = true
    If I am understanding the manual correctly, I can't configure HSERIN for inverted mode.
    Here is the HSERIN code
    define CODE_SIZE 48
    define OSC 8
    Include "modedefs.bas"    ' Mode definitions for Serout
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $20 ' Enable transmit, BRGH = 0
    SPBRG = 12  ' 9600 Baud @ 8MHz, 0.16%
    DEFINE HSER_SPBRG 12  ' 9600 Baud @ 8MHz, 0.16%
    ''''''''THIS IS WHAT I NORMAL USE TO CONFIGURE TX/RX for SERIAL
    'DEFINE DEBUG_REG PORTC
    'DEFINE DEBUG_BIT 5
    'DEFINE DEBUG_BAUD 9600
    'DEFINE DEBUG_MODE 1    ' 1 = inverted, 0 = true
    'DEFINE DEBUGIN_REG PORTC
    'DEFINE DEBUGIN_BIT 7
    'DEFINE DEBUGIN_MODE 1  ' 1 = inverted, 0 = true
    Switch4           var     PortD.0
    Switch3           var     PortE.2
    Switch2           var     PortC.0
    Switch1           var     PortC.3
    MotorSpeed        var     PortC.1
    Population        var     PortC.2
    Enable4           var     PortD.1
    Enable3           var     PortD.2
    Enable2           var     PortD.3
    Enable1           var     PortD.4
    Input1            var     PortB.1
    Input2            var     PortB.4
    Input3            var     PortB.3
    Input4            var     PortD.7
    LCD               var     PortD.5
    WTX               Var     PortC.5
    WRX               var     PortC.7
    StandAlone        var     PortD.6
    RPM               var     word
    Duty1             Var     Word
    Duty2             Var     Word
    Duty3             Var     Word
    Duty4             Var     Word
    Duty1S            data    word      200 '20% Duty Cycle
    Duty2S            data    word      400 '20% Duty Cycle
    Duty3S            data    word      600 '20% Duty Cycle
    Duty4S            data    word      800 '20% Duty Cycle
    HighCycle         var     word
    LowCycle          var     word
    BCD1              var     byte
    BCD10             var     byte
    TotalRate         var     word
    TotalRate1        var     word
    TotalRate2        var     word
    TotalRate3        var     word
    TotalRate4        var     word
    RPM1              var     word
    RPM2              var     word
    RPM3              vaR     WORD
    RPM4              VAR     WORD
    MotorCount        var     byte              'Tracks motorspeed input
    HighTime1         var     word
    LowTime1          var     word
    HighTime2         var     word
    LowTime2          var     word
    HighTime3         var     word
    LowTime3          var     word
    HighTime4         var     word
    LowTime4          var     word
    TotalTime1        var     word
    TotalTime2        var     word
    TotalTime3        var     word
    TotalTime4        var     word
    Freq              var     word
    UpperLimit        VAR     word
    LowerLimit        VAR     word
    ChannelCount      var     byte
    TotalTime         var     word
    MaxTotalTime      var     word
    UnitID            var     byte
    EPDID             var     byte
    Rate1             var     word
    Rate2             var     word
    Rate3             var     word
    Rate4             var     word
    T1                var     word  'Used to measure RPM
    T2                var     word  'Used to measure RPM
    T3                var     word  'Used to measure RPM
    RSTATE1           var     byte
    RSTATE2           var     byte
    RSTATE3           var     byte
    RSTATE4           var     byte
    GoodBad           var     bit
    Prefix            con     $FE
    LcdCls            CON     $51
    CursorPS          con     $45
    Backlight         con     $53
    Contrast          con     $52
    INTCON.7 = 1
    INTCON.6 = 1
    INTCON2.7 = 1         'Pull Ups disabled
    ADCON0 = 0            'A/D OFF
    ANSEL0 = %00010000    'All analogue channels to digital except AN4
    ANSEL1 = %00000000    'All analogue channels to digital
    TRISA = %111111       'PortA to inputs
    TRISB = %00100000     'PortB to outputs, except B5----------------------------------------------------04
    TRISC = %10010110     'PortC, Switch3 and Switch4 outputs; Motorspeed and Population inputs
    TRISD = %01000000     'PortD, Switch 1 output; Enable1-4
    TRISE = %011
    PWMCON0=%01111111     'All odd PWMs enabled, all independent
    PTCON0 = %00001000    '2.0khz=00000100 2.9khz=00000000          '400hz/20Mhz=00001000
    Freq= 249             '2.0kHz=249 2.9kHz=50000           '400hz/20mHz=50000
    LowerLimit=100        '200 is 6%
    UpperLimit=1000       '1000=100% (Max is 3332 3000 is 90% for 2.9khz)
    PTPERL =Freq.LowByte              '
    PTPERH =Freq.HighByte
    Symbol Capture = PIR2.0 ' CCP2 capture flag
    Symbol Overflow = PIR1.0
    Overflow = 0            '
    PWMCON1 = 1             ' updates enabled, overrides sync w/timebase
    PTCON1 = %11000000      ' PWM time base is ON, counts up  500hz
    FLTCONFIG = %00000000   ' enable fault A, cycle-by-cycle mode
    RCSTA.7=1 'SPEN serial port enable bit
    INTCON = 0              ' Interrupts off
    CCP2CON = %00000101     ' Capture mode, capture on rising edge
    T2CON = %10000001       ' TMR1 prescale=1, clock=Fosc/4, TMR1=on
    T1CON = %10010001       ' TMR1 prescale=1, clock=Fosc/4, TMR1=on
    rpm=0
    TotalTime1=0
    MaxTotalTime=20000
    Serout2 LCD, 84, [Prefix,LcdCLS]
    pause 10
    SEROUT2 LCD,84, [Prefix,CursorPS,0, "EPD HSERINTEST"]
    pause 2000
            INT_Handler    RX_INT,  _Get_char,   PBP,  yes
    @   INT_ENABLE   RX_INT     ; enable external (INT) interrupts
    goto OverISRs:
    Get_char:
      HSERIN  100, BadData, [wait ("I"),RPM.LowByte,rpm.highbyte,RSTATE1,RSTATE2,RSTATE3,RSTATE4]
      GoodBad=1
      goto GoodData
      BadData:
      goodBad=0
      GoodData:
    @ INT_RETURN
    OverISRs:
    RunAround:
      gosub DisplayData
    goto RunAround
    DisplayData:
      If GoodBad = 1 then
        SEROUT2 LCD,84, [Prefix,CursorPS,0, "Good Data"]
        SEROUT2 LCD,84, [Prefix,CursorPS,0, "Bad Data"]
      GoodBad = 0
    MeasureRPM:
      If MotorCount = 1 then
        If Enable1 = 0 then
          High Switch1
          Low Switch2
          Low Switch3
          Low Switch4
          gosub Get_RPM
          hightime1=HighCycle
          lowtime1=lowcycle
          TotalTime1 = HighTime1+LowTime1
      If MotorCount = 2 then
        If Enable2 = 0 then
          Low Switch1
          High Switch2
          Low Switch3
          Low Switch4
          gosub Get_RPM
          hightime2=HighCycle
          lowtime2=lowcycle
          TotalTime2 = HighTime2+LowTime2
      EndIf
      If MotorCount = 3 then
        If Enable3 = 0 then
          Low Switch1
          Low Switch2
          High Switch3
          Low Switch4
          gosub Get_RPM
          hightime3=HighCycle
          lowtime3=lowcycle
          TotalTime3 = HighTime3+LowTime3
      Endif
      If MotorCount = 4 then
        If Enable4 = 0 then
          Low Switch1
          Low Switch2
          Low Switch3
          High Switch4
          gosub Get_RPM
          hightime4=HighCycle
          lowtime4=lowcycle
          TotalTime4 = HighTime4+LowTime4
      If MotorCount = 4 or Motorcount >4 then
        MotorCount = 1
        MotorCount = MotorCount + 1
    NoRPM:
          HighCycle = 0  ' High pulse width = T2 - T1
          LowCycle = 0
          overflow = 0
    Get_RPM:
        pauseus 300
        Capture = 0
        CCP2CON = %00000101
        overflow = 0
        WHILE Capture=0 and overflow=0
        WEND
        If OVerflow=1 then
          goto NoRPM
        T1.HighByte = CCPR2H : T1.LowByte = CCPR2L
        Capture = 0
        CCP2CON.0 = 0
        Wend
        If OVerflow=1 then
          goto NoRPM
        T2.HighByte = CCPR2H : T2.LowByte = CCPR2L
        Capture = 0
        CCP2CON.0 = 1
        Wend
        If OVerflow=1 then
          goto NoRPM
        T3.HighByte = CCPR2H : T3.LowByte = CCPR2L
        CCP2CON = 0
        HighCycle = T2-T1
        LowCycle = T3-T2
    BCD:
      BCD1=PORTA
      BCD1=BCD1 & $0F
      BCD1=BCD1^ $0F
      Unitid=bcd1
    '  BCD1=PORTA
    '  BCD1=BCD1 & $F0
    '  BCD1=BCD1^ $F0
    '  BCD1 = BCD1 >>4
    '  Unitid=bcd1
