Serin2,Serout2,Wait problem
Results 1 to 17 of 17
    Default Re: Serin2,Serout2,Wait problem
    Add a time-out to the wait.
    I thought TIMEOUT would only work when the incoming line wasn't active at all. If there is data on the input pin even if its wrong Timeout won't happen if I read the info correctly.
    Here is something from Bruce that will time-out and active serial port. Works very well for radios.
    '*  Name    : DEC.BAS                                           *
    '*  Author  : B. Reynolds                                       *
    '*  Notice  : Copyright (c) 2009 Reynolds Electronics           *
    '*  Date    : 11/15/2009                                        *
    '*  Version : 1.0 (Momentary decoder version)                   *
    '*  Notes   : 4-BIT DECODER IC FOR RF REMOTE CONTROL            *
    '*          : USING THE PIC12F635                               *
    @ DEVICE PIC12F635,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_OFF
    @ DEVICE PWRT_ON,FCMEN_OFF,IESO_OFF,WUREN_OFF,PROTECT_OFF
        DEFINE NO_CLRWDT 1      ' Watchdog timer is disabled, so we don't need to reset it
        DEFINE INTHAND RESET_VT ' Interrrupt on Timer1 overflow to reset outputs in 65.5mS
                                ' if no serial data received in this time period
        SYMBOL  MODE = GPIO.3   ' baud select. 1=4800, 0=2400
        SYMBOL  D_IN = GPIO.5   ' Encoder data input pin
        SYMBOL  TMR1IF = PIR1.0 ' Timer1 overflow interrupt flag (reset in int handler)
        SYMBOL  TMR1IE = PIE1.0 ' Timer1 interrupt enable bit
        'Variables for saving state in interrupt handler
        wsave    VAR    BYTE $70 system        ' Saves W
        ssave    VAR    BYTE bank0 system    ' Saves STATUS
        psave    VAR    BYTE bank0 system    ' Saves PCLATH
        fsave    VAR    BYTE bank0 system    ' Saves FSR
        ' Working variables
        MATCH     VAR BYTE bank0 system ' Match variable
        DAT_IN1   VAR BYTE  ' 1st Data byte
        DAT_IN2   VAR BYTE  ' 2nd Data byte for verify
        CHK_SUM   VAR BYTE  ' Holds checksum received
        CheckSum  VAR BYTE  ' Checksum of data bytes received
        LOOPS     VAR BYTE  ' Loop var
        BAUD      VAR WORD  ' Holds baud rate
        ' Constants
        Synch    CON "~"    ' 01111110 synch byte
        N2400    CON 16780  ' 2400 bps inverted
        N4800    CON 16572  ' 4800 bps inverted
         ' hardware init
        GPIO = 0            ' Clear outputs on power-up
        TRISIO = 101000  ' GPIO.5=data input, GPIO.3=baud select input
        WPUDA = 0           ' Disable weak pull-ups
        IOC = 0             ' Interrupt on change disabled
        VRCON = 0           ' Comparator Vref disabled
        CMCON0 = 7          ' Disable comparators
        OSCCON = 100000  ' Internal 4MHz select
        OPTION_REG = 128    ' Pull-ups off
        ' Setup Timer1 for resets after ~65.5mS
        T1CON = 000000   ' Internal clock, 1:1 prescale, Timer1 off for now
        TMR1L = 0
        TMR1H = 0           ' Timer1 low & high bytes cleared
        TMR1IF = 0          ' Clear Timer1 overflow flag before enabling interrupt
        TMR1IE = 1          ' Enable Timer1 overflow interrupt
        INTCON = 000000  ' Global & peripheral ints enabled
        MATCH = 0           ' Clear match count
        GOTO    MAIN        ' Jump over int handler
    RESET_VT
        movwf    wsave            ; Save W
        swapf    STATUS, W        ; Swap STATUS to W (swap avoids changing STATUS)
        clrf    STATUS            ; Clear STATUS
        movwf    ssave            ; Save swapped STATUS
        movf    PCLATH, W        ; Move PCLATH to W
        movwf    psave            ; Save PCLATH
        movf    FSR, W            ; Move FSR to W
        movwf    fsave            ; Save FSR
        ; Do interrupt stuff here
        bcf     T1CON,TMR1ON    ; Stop Timer1
        clrf    TMR1L           ; Clear low byte
        clrf    TMR1H           ; Clear high byte
        bcf     PIR1,TMR1IF     ; Clear Timer1 interrupt flag bit
        clrf    GPIO            ; Clear outputs on button release (or timeout)
        clrf    MATCH           ; Clear match variable
        ; Restore FSR, PCLATH, STATUS and W registers
        movf    fsave, W        ; retrieve FSR value
        movwf    FSR                ; Restore it to FSR
        movf    psave, W        ; Retrieve PCLATH value
        movwf    PCLATH            ; Restore it to PCLATH
        swapf    ssave, W        ; Get swapped STATUS value (swap to avoid changing STATUS)
        movwf    STATUS            ; Restore it to STATUS
        swapf    wsave, F        ; Swap the stored W value
        swapf    wsave, W        ; Restore it to W (swap to avoid changing STATUS)
        bsf     T1CON,TMR1ON    ; Re-enable Timer1 before exiting interrupt handler
        retfie                    ; Return from the interrupt
    MAIN:
        ' Set data rate
        IF MODE = 1 THEN
           BAUD = N4800
           BAUD = N2400
        ' Fire up Timer1 before entry to serial input routine
        T1CON.0 = 1
        ' at 4MHz Timer1 overflows in 65536 * 1uS (~65.5mS) if no Synch byte
        ' and serial data arrive on time. SERIN2 timeout & label options
        ' are useless with a noisy RF receiver output - as noise continually
        ' resets the timeout period causing it to hang forever.
        ' Wait for Synch byte, then get new inbound data & checksum
        SERIN2 D_IN,BAUD,[WAIT(Synch),DAT_IN1,DAT_IN2,CHK_SUM]
        T1CON.0 = 0    ' Stop Timer1 once we've received data
        TMR1L = 0      ' Clear low byte
        TMR1H = 0      ' Clear high byte
        ' / **** Begin data validation **** /
        ' Calculate checksum
        CheckSum = DAT_IN1 + DAT_IN2
        ' Test new checksum against one received in CHK_SUM
        IF CheckSum != CHK_SUM THEN MAIN ' Failed checksum, return
        ' Test data bytes for match
        IF DAT_IN1 != DAT_IN2 THEN MAIN ' Failed data comparison, return
        MATCH = MATCH + 1        ' We have a match so increment match count
        IF MATCH = 2 THEN DECODE ' Everything matched twice, we're good
        GOTO Main                ' Else do it all over
        ' Everything looking good - so place new data on outputs
    DECODE:
        ' Place decoded values on port pins..
        GPIO = (DAT_IN1 & 010111)
        DAT_IN1 = !DAT_IN2  ' Destroy the match
        MATCH = 0
        GOTO MAIN
    The forum is stripping off "%". But you should get the idea.
    Sep 2005
    Campbell, CA
    Tobias, is there some reason why you aren't using the HARDWARE serial port? Using interrupts on the receive side solves 90% of all problems.
    Charles Linquist
    I have the wireless module connected to the hardware serial port pins but I have never used that before. Is there any good reading to learn how?
    Sep 2005
    Campbell, CA
    It is just as easy as using SERIN/SEROUT
    I don't know what speed your chips are running - but.
    Use MisterE's PIC Multi-Calc to help you set up the proper DEFINES
    Then use something like the following:
        CR CON 13
        LF  CON 10
        DataStatus = 0
        INTCON.7 = 1
        INTCON.6 = 1
            INCLUDE "DT_INTS-18.bas"         ; Base Interrupt System
            INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
                   INT_Handler    RX1_INT,    _GetChar,    PBP,  yes
        INT_CREATE
      goto OverISRs:
    GetChar:
              HSEROUT[CR,LF,"At least some data received"]    ;     THIS IS JUST FOR DEBUG!!!  REMOVE IN ACTUAL PGM.
                         HSERIN 15,BadData,[wait ("P"),UnitID2,TotalRate1.lowbyte,TotalRate1.Highbyte,TotalRate2.lowbyte,TotalRate2.Highbyte,_
                           TotalRate3.lowbyte,TotalRate3.Highbyte,TotalRate4.lowbyte,TotalRate4.Highbyte,OFI1,OFI2,OFI3,OFI4]
             DataStatus = 1
            GOTO GoodData
    BadData:
              DataStatus.7 = 1
    GoodData:
    @ INT_ENABLE RX1_INT
    @ INT_RETURN
    OverISRs:
    MAIN:
          If DataStatus.0  then
             HSEROUT [CR,LF,#UnitID2,#TotalRate1,"  .............................
          if DataStatus.7 then
             HSEROUT [CR,LF,"Data Error!"]
             DataStatus = 0
    I haven't actually tested this but it should work.
    Charles Linquist
    Sep 2005
    Campbell, CA
    I missed something in my earlier post - between OVERISRs and MAIN you need the line
    Also, you can use LEDs in place of the HSEROUTs to show you have reached that point in the code (as a debugging aid).
    Charles Linquist
