It is just as easy as using SERIN/SEROUT
I don't know what speed your chips are running - but.
Use MisterE's PIC Multi-Calc to help you set up the proper DEFINES
Then use something like the following:
    CR CON 13
    LF  CON 10
    DataStatus = 0
    INTCON.7 = 1
    INTCON.6 = 1
        INCLUDE "DT_INTS-18.bas"         ; Base Interrupt System
        INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
               INT_Handler    RX1_INT,    _GetChar,    PBP,  yes
    INT_CREATE
  goto OverISRs:
GetChar:
          HSEROUT[CR,LF,"At least some data received"]    ;     THIS IS JUST FOR DEBUG!!!  REMOVE IN ACTUAL PGM.
                     HSERIN 15,BadData,[wait ("P"),UnitID2,TotalRate1.lowbyte,TotalRate1.Highbyte,TotalRate2.lowbyte,TotalRate2.Highbyte,_
                       TotalRate3.lowbyte,TotalRate3.Highbyte,TotalRate4.lowbyte,TotalRate4.Highbyte,OFI1,OFI2,OFI3,OFI4]
         DataStatus = 1
        GOTO GoodData
BadData:
          DataStatus.7 = 1
GoodData:
@ INT_ENABLE RX1_INT
@ INT_RETURN
OverISRs:
MAIN:
      If DataStatus.0  then
         HSEROUT [CR,LF,#UnitID2,#TotalRate1,"  .............................
      if DataStatus.7 then
         HSEROUT [CR,LF,"Data Error!"]
         DataStatus = 0
I haven't actually tested this but it should work.
