What part are you having trouble with? Have you written any code yet or is this still is the conceptual stage?
Your code in the PDF is not PicBasicPro. Sorry, I do not do JAL.
http://melabs.com/samples/PBP-mixed/onint.htm
For a different chip.
What version of PBP do you have?
Sorry for the noob answer...the pbp3 demo version doesn't support 12f675, no wonder I didn't hear back from you..sorry. I have proton ide 3.5.2.7. I have a code which close to what I need, but I think is something wrong with, because it doesn't seem to work, and it needs to modified a bit. I need it to have a 10 second delay before the flashing begins, and it needs to continue flashing until the switch goes open again, which would then return to sleep, ready for the next interrupt caused by the switch to begin the process again. This code doesn't seem to do anything...I have tried heaps of other codes on my pic and they work fine.
'A change from Vdd to Vss on GPIO.4 will cause the 12F675 to wake up
'It will then blink a LED 10 times and go back to sleep
'Front end setup
Device = 12F675
Config WDT_OFF,PWRTE_ON,CP_OFF,MCLRE_OFF,BODEN_OFF
TRISIO=24 'sets GPIO.3 and GPIO.4 as inputs and all others as outputs (or 011000)
CMCON=7 'turns off comparator function [CMCON0=7]
ADCON0=0 'no ADC - doesn't seem necessary but may be a good idea
ANSEL=0 'no ADC input - IMPORTANT if using ports in digital mode
VRCON=0 'turns off voltage reference to minimize sleep current
INTCON=8 'Enables port change interrupt ie GPIE
IOCB=16 'sets GPIO.4 for Interrupt on change [IOC=16]
OPTION_REG.6=0 'INT on falling edge
OPTION_REG.7=0 '00000000 WPU enabled,
WPU=38 '00100110 = 38 set unused ports 1,2 and 5 tied to weak pull-up resistors
'Define Variables
wakeup VAR GPIO.4 'input, interrupt on change.
LED VAR GPIO.0 'LED output
x VAR Byte
'Initial settings
LED=0
'Program
START:
INTCON.0=0
DelayMS 100
@ Sleep
DelayMS 100
For x= 1 To 10
LED=1
DelayMS 500
LED=0
DelayMS 500
Next x
GoTo START
