Voltage Ref Problem
Results 1 to 6 of 6
    Jan 2012
    Default Voltage Ref Problem
    Marry Christmas and Happy New Year everyone!
    I am using pic12F675, picbasic pro compiler.
    I use ADCON0.6=1 uses GPIO.1 as Vref then ADCIN 0, VA it works ok
    then I use ADCON0.6=0 to use the Vdd as Vref then ADCIN 3, VA1 it will not work...no readings
    Adin 0 uses external Vref and Adin 3 uses the VDD
    how can I read both 0 and 3 with different Vref
    I use the following:
    ADCON0.6=1
    ADCIN 0, VA
    ADCON0.6=0
    ADCIN 3,VA1
    what is the problem? can't I use different Vref in the same program?!
    Please help!
    Default Re: Voltage Ref Problem
    Does it give you a reading if you don't switch VRef?
    I'm guessing you have the TRIS and/or ANSEL set wrong for the particular pin (GP4) but you don't show that part of your code so it's hard to say.
    Sep 2005
    Campbell, CA
    Do you have ANSEL set to %00011011 ?
    ANCON0.7 = 1 ?
    TRISIO.0 = 1
    TRISIO.1 = 1
    TRISIO.4 = 1
    My guess is that you have the Vref pin configured as digital, or as an output
    Charles Linquist
    Jan 2012
    This is what I have set:
    trisio = %00011011
    ANSEL = %00001011
    CMCON = %01010111
    ADCON0.7 = 1 ' Set PORTA analog and right justify result
    ADCON0.6=1
    ADCIN 0, VA
    ADCON0.6=0
    ADCIN 3,VA1
    Thanks for help
    Sep 2005
    Campbell, CA
    Are VA and VA1 WORD variables?
    Charles Linquist
    Puerto Rico
    'For global reference to system voltage, use the Voltage variable, which is based on a
    'scale of 1 to 1000, with 775 = 7.75 volts. Remember that the resistors on the board
    'divide the actual battery voltage in half so the ADC can "digest" it without damage.
    'ADCIN voltages are limited to 5. Both EGT and Voltage are compared with the onboard
    'precision voltage reference which delivers a perfect 5V.
    '**Voltage**
    LCDVLow=0
    LCDVHigh=0
    Voltage=0
    ADCIN VoltChannel, Voltage 'Take just 1 voltage sample. 7.6V = 194
    ' SerOut LCDScreen, T9600, [LCDCmd, LCDLine1,"VoltsX=",#Voltage] 'RPM
    ' PAUSE 2000
    Voltage = Voltage * 4 '194 * 4 = 776
    LCDVHigh = Voltage / 100 '776 / 100 rounds to 7
    LCDVLow = (Voltage // 100) / 10 '776 // 100 = 76, 76 / 10 = 7
    LCDVLow = LCDVLow - 2
    'Final Display = 7.7
    My Hobbies is PicBasic PRO
