18F97J60 functions
Results 1 to 3 of 3
    May 2007
    Default Re: 18F97J60 functions
    See section 24.3 of the data sheet.
    All of the PIC18F97J60 family devices power their core
    digital logic at a nominal 2.5V. This may create an issue
    for designs that are required to operate at a higher
    typical voltage, such as 3.3V. To simplify system
    design, all devices in the PIC18F97J60 family incor-
    porate an on-chip regulator that allows the device to
    run its core logic from VDD.
    The regulator is controlled by the ENVREG pin. Tying
    VDD to the pin enables the regulator, which in turn,
    provides power to the core from the other VDD pins.
    If ENVREG is tied to VSS, the regulator is disabled. In
    this case, separate power for the core logic, at a nomi-
    nal 2.5V, must be supplied to the device on the
    VDDCORE/VCAP pin
    to run the I/O pins at higher voltage
    levels, typically 3.3V. Alternatively, the VDDCORE/VCAP
    and VDD pins can be tied together to operate at a lower
    nominal voltage.
    Thanks for pointing me in the right direction. So on this board I want to use a 3.3v regulator so I need to enable the internal regulator. Am I on the right track with the attached schematic? Also the spec sheet mentions to make sure AVDD and AVSS are connected. All of my channels are digital but I connected AVDD to the 3.3v + and AVSS to the 3.3V-
    Schematic.pdf
