Google App Inventor
Results 1 to 22 of 22
    Dec 2005
    Default Re: Google App Inventor
    Anand,
    I've been too busy with 15 different PCB prototypes to spend much time with B4A so I can't add to what Dave has said but everyone I know who has it has been impressed. There's a user forum that should give you a good idea of how it is used and how well it is supported. Anybody familiar with any dialect of procedural Basic (and especially VB) should find it easy to learn.
    Dave (macrackit), thanks for the code; a working piece of code should be an excellent starting point while learning.
    Dave (Houston), I remember you had referred to B4A in an earlier thread as well, and had meant to try it out back then, but somehow got relegated to the background. I see from the forums and the projects sub-section that people have done some pretty fancy things with B4A. What I need seems pretty trivial in comparison, so I'm pretty sure its doable.
    I'll report back with the progress as I go.
    Thanks, guys.
    Anand
    Here is the whole project, graphics and all.
    Here I am, back as promised. Finally got the app done in App Inventor, and am pretty pleased with the results.
    It does what I want well; send an ascii character over BT for each button pressed. Its supposed to be used as a numeric keypad for access control.
    I would still be looking up Basic4Android (or other alternates) for a couple reasons, though.
    1) Apps created with App Inventor cannot be installed to the SD card. (Not without a tweak, anyway)
    2) The apk file size is not very compact; I've read it can be as much as 6 to 10 times larger than the same app developed in say, B4A.
    3) Of course the degree of uncertainty regarding its new home at MIT; it goes off the Google site on the 31st.
    Dave, your zip file would be the ideal starting point for me to get into B4A, thanks. Although it does look a bit daunting..
    Anand
    It is not as bad as it looks. Most of the stuff in the zip was created by B4A.
    Oh okay, I will take the plunge then.
    Also found their pdf manual to be a great way to start.
    Anand
    Feb 2010
    USA, New England
    Dave,
    Thank you, thank you, thank you telling us about B4A! Trying to create Android apps using Eclipse and Java was driving me up a tree. I've purchase it and am absolutely delighted with it so far.
    You remain the best!
    Best Regards,
    Paul
