Google App Inventor
Results 1 to 22 of 22
    Default Re: Google App Inventor
    I have not used BT yet. Used the GPS, compass/accelerometer, write/read to storage... Currently I am working on a database app for an archaeologist that will record position and user entered attributes, with the ability to sync the data once the device is back into cell/wifi range. The learning curve for me was less than App Inventor. I never really made anything useful with App Inventor... But that is me.
    Here is the code for a test app when I started playing with the GPS and the other orientation things.
    The apk is attached if you want to see what it does.
    'Activity module
    Sub Process_Globals
        'These global variables will be declared once when the application starts.
        'These variables can be accessed from all modules.
        Dim GPS1 As GPS
        Dim Orientation As PhoneOrientation
        'Compass Stuff
        Dim Angle As Float
        Dim Timer1 As Timer
    End Sub
    Sub Globals
        'These global variables will be redeclared each time the activity is created.
        'These variables can only be accessed from this module.
        Dim Button1 As Button
        Dim Button2 As Button
        Dim Button3 As Button
        Dim Button4 As Button
        Dim ScrollView1 As ScrollView
        Dim lblAcu As Label
        Dim lblAlt As Label
        Dim lblLat As Label
        Dim lblLon As Label
        Dim lblSatellites As Label
        Dim lblSpeed As Label
        Dim pnlTest As Panel
        Dim Alt    As    Double
        Dim Rate As Double
        Dim Acu As Double
        Dim Latx As Double
        Dim Lonx As Double
        Dim now As Long
        Dim lblBear As Label
        Dim lblCompass As Label
        'Compass Stuff
        Dim csvCompass, csvNeedle As Canvas
        Dim bmpCompass, bmpNeedle As Bitmap
        Dim imvCompass, imvNeedle As ImageView
        Dim RectCompass, SRectNeedle, DRectNeedle As Rect
    End Sub
    Sub Activity_Create(FirstTime As Boolean)
        Activity.LoadLayout("Main")
        ScrollView1.Panel.LoadLayout("scrollviewlayout")
        ScrollView1.Panel.Height = pnlTest.Height
        EditMode
        If FirstTime Then
            GPS1.Initialize("GPS")
        End If
        If File.ExternalWritable = True Then
            Msgbox("Can write to SD storage card!", "")
        End If
        WriteTextWriter
    End Sub
    Sub Activity_Resume
        If GPS1.GPSEnabled = False Then
            ToastMessageShow("Please enable the GPS device.", True)
            StartActivity(GPS1.LocationSettingsIntent) 'Will open the relevant settings screen.
        Else
            GPS1.Start(0, 0) 'Listen to GPS with no filters.
        End If
        Orientation.StartListening("Orientation")
    End Sub
    Sub Activity_Pause (UserClosed As Boolean)
        GPS1.Stop
        Orientation.StopListening
    End Sub
    Sub GPS_LocationChanged (Location1 As Location)
        lblLat.Text = "Lat = " & Location1.ConvertToMinutes(Location1.Latitude)
        lblLon.Text = "Lon = " & Location1.ConvertToMinutes(Location1.Longitude)
        Latx = Location1.Latitude
        Lonx = Location1.Longitude
        ' 1 meter per second = 2.23693629 miles per hour
        Rate = Round2(Location1.Speed * 2.23693629,3)
        lblSpeed.Text = "Speed (MPH)= " & Rate
        ' 1 meter = 3.2808399 feet
        Alt = Round2(Location1.Altitude * 3.2808399,3)
        lblAlt.Text = "Altitude (Feet)= " & Alt
        Acu = Round2(Location1.Accuracy * 3.2808399,3)
        lblAcu.Text = "Accuracy (Feet)= " & Acu
        lblBear.Text = "GPS Bearing = " & Location1.Bearing
    End Sub
    Sub GPS_UserEnabled (Enabled As Boolean)
        ToastMessageShow("GPS device enabled = " & Enabled, True)
    End Sub
    Sub GPS_GpsStatus (Satellites As List)
        lblSatellites.Text = "Satellites:" & CRLF & _
        "#  SNR Used  Azi  Elev" & CRLF
        For i = 0 To Satellites.Size - 1
            Dim Satellite As GPSSatellite
            Satellite = Satellites.Get(i)
            lblSatellites.Text = lblSatellites.Text & CRLF & Satellite.Prn & _
                "  " & Satellite.Snr & "  " & Satellite.UsedInFix & "  " & Satellite.Azimuth _
                & "  " & Satellite.Elevation
        Next
    End Sub
    Sub Button1_Click
          WriteTextWriter
          Msgbox("The date is: " & DateTime.Date(now) & CRLF & _
        "The time is: " & DateTime.Time(now), "")
    End Sub
    Sub Button2_Click
        ReadStringExample
    End Sub
    Sub ReadStringExample
        Msgbox(File.ReadString(File.DirRootExternal, "MAC_GPS.txt"), "")
    End Sub
    Sub WriteTextWriter()
        now = DateTime.Now
        Dim TextWriter1 As TextWriter
        TextWriter1.Initialize(File.OpenOutput(File.DirRootExternal,"MAC_GPS.txt", True))
      '  For i = 1 To 10
      '      TextWriter1.WriteLine("Line" & i)
      '  Next
          TextWriter1.WriteLine("Date = " & DateTime.Date(now))
        TextWriter1.WriteLine("Time = " & DateTime.Time(now))
        TextWriter1.WriteLine("Lat = " & Latx)
        TextWriter1.WriteLine("Lon = " & Lonx)
        TextWriter1.WriteLine("Alt = " & Alt)
        TextWriter1.WriteLine(" ")
        TextWriter1.Close
    End Sub
    Sub Orientation_OrientationChanged (Azimuth As Float, Pitch As Float, Roll As Float)
        lblCompass.Text = "Compass = " & Azimuth
        Angle = Azimuth
        Timer1_Tick
    End Sub
    Sub Timer1_Tick
        csvNeedle.DrawRectRotated(DRectNeedle,Colors.Transparent,True,1,0)
        csvNeedle.DrawBitmapRotated(bmpNeedle,SRectNeedle,DRectNeedle,0)
        csvCompass.DrawBitmapRotated(bmpCompass,RectCompass,RectCompass,-Angle)
        imvCompass.Invalidate2(RectCompass)
    End Sub
    Sub EditMode()
        'Compass Stuff
        Dim x, y As Float
        bmpCompass.Initialize(File.DirAssets,"compass.png")
        bmpNeedle.Initialize(File.DirAssets,"needle.png")
        imvCompass.Initialize("")
        imvCompass.Bitmap = bmpCompass
        imvNeedle.Initialize("")
        imvNeedle.Color=Colors.Transparent
        x = 30 ' (100%x - bmpCompass.Width)/2
        y = 410 '(100%y - bmpCompass.Height) / 2
        ScrollView1.Panel.AddView(imvCompass, x, y, bmpCompass.Width, bmpCompass.Height)
        ScrollView1.Panel.AddView(imvNeedle, x, y, bmpCompass.Width, bmpCompass.Height)
        csvCompass.Initialize(imvCompass)
        RectCompass.Initialize(0, 0, bmpCompass.Width, bmpCompass.Height)
        csvNeedle.Initialize(imvNeedle)
        x = (bmpCompass.Width - bmpNeedle.Width)/2
        y = (bmpCompass.Height - bmpNeedle.Height)/2
        SRectNeedle.Initialize(0, 0, bmpNeedle.Width, bmpNeedle.Height)
        DRectNeedle.Initialize(x, y, x + bmpNeedle.Width, y + bmpNeedle.Height)
        Timer1.Initialize("Timer1",200)
        Timer1_Tick
    End Sub
    Dec 2005
    Anand,
    I've been too busy with 15 different PCB prototypes to spend much time with B4A so I can't add to what Dave has said but everyone I know who has it has been impressed. There's a user forum that should give you a good idea of how it is used and how well it is supported. Anybody familiar with any dialect of procedural Basic (and especially VB) should find it easy to learn.
    Dave (macrackit), thanks for the code; a working piece of code should be an excellent starting point while learning.
    Dave (Houston), I remember you had referred to B4A in an earlier thread as well, and had meant to try it out back then, but somehow got relegated to the background. I see from the forums and the projects sub-section that people have done some pretty fancy things with B4A. What I need seems pretty trivial in comparison, so I'm pretty sure its doable.
    I'll report back with the progress as I go.
    Thanks, guys.
    Anand
    Here is the whole project, graphics and all.
    Here I am, back as promised. Finally got the app done in App Inventor, and am pretty pleased with the results.
    It does what I want well; send an ascii character over BT for each button pressed. Its supposed to be used as a numeric keypad for access control.
    I would still be looking up Basic4Android (or other alternates) for a couple reasons, though.
    1) Apps created with App Inventor cannot be installed to the SD card. (Not without a tweak, anyway)
    2) The apk file size is not very compact; I've read it can be as much as 6 to 10 times larger than the same app developed in say, B4A.
    3) Of course the degree of uncertainty regarding its new home at MIT; it goes off the Google site on the 31st.
    Dave, your zip file would be the ideal starting point for me to get into B4A, thanks. Although it does look a bit daunting..
    Anand
    It is not as bad as it looks. Most of the stuff in the zip was created by B4A.
    Oh okay, I will take the plunge then.
    Also found their pdf manual to be a great way to start.
    Anand
