Charles and Henrik;
Preloading TMR3 Worked like a charm, I made it go just a little faster than I need just for some room for error. With a preload of:
I put this at the end of my TMR3 interupt routine to preload:Code:TMR3Preload CON 51650
Seems to run at 355-360 hz. The error is probably in how I'm capturing the frequency, it's probably more accurate than that. That's what I need though, MISTER E's MultiCalc is handy for this, so thanks also to Mister E and everyone else. I didn't know I could preload the timer, I'm learning more all the time.Code:T3CON.0 = %0 'Turn Timer Off To preload for frequency I need. TMR3Now.Highbyte = TMR3H TMR3Now.LowByte = TMR3L TMR3Now = TMR3Now + TMR3PreLoad TMR3H = TMR3Now.HighByte TMR3L = TMR3Now.LowByte T3Con.0 = %1 'Turn Timer on
Thanks Again,
Shane
