20Mhz crystal cause led to blink irreguarly
Results 1 to 4 of 4
    niknaksbarbeque's Avatar
    niknaksbarbeque Guest
    Default 20Mhz crystal cause led to blink irreguarly
    Has anyone had trouble getting a 20 mhz crytal with a breadboard and Pic18f452 working reliably.
    All I want to do is just make a light blink on and off (reguarly). Everything works fine with a 4MHz crystal (the light blinks reguarly). But when I switch the Crystal to 20 Mhz, update the Configuration Oscilator setting to HS and put DEFINE OSC 20 at the top of my code the light blinks but, its really irregular. (I also made sure that the "update configuration from file setting is switched off"). I have the correct value of capicators for the crystal also.
    I'm about to tear my hair out.
    Here's my code
    DEFINE OSC 20
    MAIN:
    high portd.1
    pause 4000
    low portd.1
    pause 4000
    GOTO main
    It's not a powered oscillator (could this be the problem)?
    Apologies if this is a really think question, just starting out and have very very basic electronics knowledge.
    Mark
    p.s. Massive Karma is going out to anyone who answers 'cause I'm about to chuck the bloody thing out the window
    Feb 2004
    Germany
    Mark,
    it is most likely your breadboard causing the problem.
    This has already been discussed here
    regards
    Ralph
    Default You'll get your place in heaven
    Thanks very much for replying, it's a wee bit lonely doing all this stuff myself, really appreciate it.
    Mark
    Talking Just incase anyone else has the same problem
    I got a 20 mhz powered crystal oscilator today and it's sorted all the problems. Didn't try the other solution 'cause I took a few days off (really was having a **** time of it and needed a wee break) and waited for the crystal from "RS Components" to come. Been reading on the web that apparently it provides a much stronger timing signal and so far that seems correct (well I've got that f*cking light blinking anyway!)
    Cheers
    Mark
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. 20 Mhz Crystal, simple blinking LED
    By BenjaminsShinob in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 06:06
  4. Novice 16F83A BLINK LED program help
    By owali in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 06:02
  5. LCD will not start
