Strange Behavior in setting several pin outputs states.
Results 1 to 20 of 20
    Dec 2011
    Default Re: Strange Behavior in setting several pin outputs states.
    I am using a PIC16F873A, I am connecting the output pins directly to an ATMEL microcontroller, the ATMEL microcontroller have pullup resistors in the corresponding inputs, but the initial state of all my output pins is set to High in the begginning of the program for the ATMEL microcontroller be compatible with negative logic.
    I am using the USART of the PIC using an Assembler routine for the interrupt handler. When I send certain message to the USART via it´s input, the program evaluates the message, then changes the pin outputs, now I am working with PAUSE 10 between each output statement.
    I can not assign directly to PORT registers because of the USART connected to some pins of PORTC.
    Thanks for all your answers!
    Sep 2005
    Campbell, CA
    So what you are saying is that you didn't try the method I mentioned about the shadow register. It should still work. On most PICs the USART takes over the function of the pins so writing to PORTC.6 and PORTC.7 is then impossible.
    Charles Linquist
    Dec 2011
    Yes, I am using your shadow method, but it only works with adding pauses this way:
    PORTC.0 = 1
    PAUSE 10
    PORTC.1 = 1
    PAUSE 10
    PORTC.2 = 1
    PAUSE 10
    PORTC.3 = 1
    If I remove the pauses, then the thing does not work...
    Thank you very much again.
    May 2007
    What if you did it like this?
     ShadowC VAR byte
     ShadowC = PORTC
     ShadowC.0 = 1
     PORTC = ShadowC
     ShadowC.1 = 1
     PORTC = ShadowC
     ShadowC.2 = 1
     PORTC = ShadowC
     ShadowC.3 = 1
     PORTC = ShadowC
    Dec 2011
    I want to thank you very much.
    The problem is resolved, now I am setting the pin output states super fast!
    The final working code was the one posted by rmteo, but thank you all really!
    ShadowC VAR byte
    ShadowC = PORTC
    ShadowC.0 = 1
    PORTC = ShadowC
    ShadowC.1 = 1
    PORTC = ShadowC
    ShadowC.2 = 1
    PORTC = ShadowC
    ShadowC.3 = 1
    PORTC = ShadowC
    You can do it even faster by doing it the way Charles originally showed you, (did you REALLY try that and it didn't work?) in other words:
    ShadowC VAR BYTE
    ShadowC = PortC
    ShadowC.0=1
    ShadowC.1=1
    ShadowC.2=1
    ShadowC.3=1
    PortC = ShadowC
    May 2007
    ShadowC VAR BYTE
    ShadowC = PortC
    ShadowC.0=1
    ShadowC.1=1
    ShadowC.2=1
    ShadowC.3=1
    PortC = ShadowC
    Even faster would be this way - but obviously the OP did not try it the way Charles described.
    ShadowC VAR BYTE
    ShadowC = PortC
    ShadowC.0 = $F
    PortC = ShadowC
