Strange Behavior in setting several pin outputs states.
Results 1 to 20 of 20
    Dec 2011
    Default Strange Behavior in setting several pin outputs states.
    Hello,
    I have used Pic Basic Pro a lot, but now I am having a strange behavior, I want to know what can be the problem:
    Here is the thing:
    For example, if I set:
    PORTC.3 = 1
    Then the Pin goes High with out problems.
    But if I write the code:
    PORTC.3 = 1
    PORTC.2 = 1
    Then pin RC3 goes Low and pin RC2 goes High!
    It seems that one instruction clears the previous one.
    I am using PIC16F873A, and Setting TRIS Registers as following:
    OUTPUT PORTC.3
    OUTPUT PORTC.2
    I am not assigning TRISC directly because my program uses USART, but that is not the problem I think because the same behavior happens with PortB!
    I am using 20Mhz oscillator and defining it in the beginning of the code.
    Thank you.
    Sep 2005
    Campbell, CA
    Default Re: Strange Behavior in setting several pin outputs states.
    This is probably a read/modify/write issue. Try the following:
    ShadowC VAR byte
    ShadowC = PORTC
    ShadowC.3 = 1
    ShadowC.2 = 1
    PORTC = ShadowC
    You can use manipulate the individual bits of the TRISC register directly if you wish. For example:
    TRISC.3 = 0
    TRISC.2 = 0
    Will work just fine.
    Charles Linquist
    Dec 2011
    Thanks for the answer Charles,
    I tried your suggestions and it does not work. The tristate of the pins is setting ok, the problem is when I try to set output states in sequential lines, for example:
    PORTC.0 = 1
    PORTC.1 = 1
    PORTC.2 = 1
    PORTC.3 = 1
    This sequence just highs the pin PORTC.3, the remaining three pins states Low.
    Dec 2011
    I discovered that adding a "PAUSE 100" statement between each pin assignment makes the thing to work. Is that normal?
    Greetings.
    Sep 2005
    Campbell, CA
    Does your device have some other function assigned to those pins that you aren't taking into account?
    Charles Linquist
    Definitely sounds like a RMW issue...
    What are you driving with the pins? LEDs without series resistor or something capacitive?
    I'm surprised you say that Charles workaround with the Shadow variable doesn't work though. Which PIC are you using? If it has LATx registers try using those instead of PORTx when setting your outputs.
    PICforBrains's Avatar
    PICforBrains Guest
    This is almost certainly a peripheral-related issue, especially if the 'pause 100' makes a difference. Something is writing to the port or turning outputs to inputs during the RMW operation.
    As Henrik asked, which PIC?
    Dec 2011
    I am using a PIC16F873A, I am connecting the output pins directly to an ATMEL microcontroller, the ATMEL microcontroller have pullup resistors in the corresponding inputs, but the initial state of all my output pins is set to High in the begginning of the program for the ATMEL microcontroller be compatible with negative logic.
    I am using the USART of the PIC using an Assembler routine for the interrupt handler. When I send certain message to the USART via it´s input, the program evaluates the message, then changes the pin outputs, now I am working with PAUSE 10 between each output statement.
    I can not assign directly to PORT registers because of the USART connected to some pins of PORTC.
    Thanks for all your answers!
    Sep 2005
    Campbell, CA
    So what you are saying is that you didn't try the method I mentioned about the shadow register. It should still work. On most PICs the USART takes over the function of the pins so writing to PORTC.6 and PORTC.7 is then impossible.
    Charles Linquist
    Dec 2011
    Yes, I am using your shadow method, but it only works with adding pauses this way:
    PORTC.0 = 1
    PAUSE 10
    PORTC.1 = 1
    PAUSE 10
    PORTC.2 = 1
    PAUSE 10
    PORTC.3 = 1
    If I remove the pauses, then the thing does not work...
    Thank you very much again.
    May 2007
    What if you did it like this?
     ShadowC VAR byte
     ShadowC = PORTC
     ShadowC.0 = 1
     PORTC = ShadowC
     ShadowC.1 = 1
     PORTC = ShadowC
     ShadowC.2 = 1
     PORTC = ShadowC
     ShadowC.3 = 1
     PORTC = ShadowC
