SD card library?
Results 1 to 23 of 23
    Dec 2009
    Canada
    Default Re: SD card library?
    Makrackit, KVLV, thanks again, I really enjoy SDFS3.zip and http://www.picbasic.co.uk/forum/cont...USB-SD-LOGGING
    Alexey
    Dec 2009
    Canada
    Hello Mackrakit,
    The code you advised works just fine, I only have one issue - when I reset MCU my program can not reinitialize the SD card until I replace it. Is this something related to the card itself or correct software should do it? I use SDC_UseHardSPI = FALSE if this matters
    Than you,
    Alexey
    I will guess that the SD card is not booted fully before your code tries to access it.
    Dec 2009
    Canada
    tried to add pause at start and it did not help, but then I learnt that I was resetting the controller at the time when the card is being accessed and this was hanging the card. Adding indication when not to reset helped
