Picbasic pro with MPLAB X
Results 1 to 9 of 9
    Default Re: Picbasic pro with MPLAB X
    Better try this one ...
    http://pbp3.com/downloads/com-melabs-pbptoolchain.zip
    must be used from MPLABX , plugins section ...
    BUT, as I read somewhere ... PicBasic Pro being a Microchip trademark ( heu, heu ... a proof I really read my manual ... ) some enlightments on how to use MPLABX would be a minimum to offer to Microchip "valued customers" ... by our beloved "Melabs" team !!!
    don't you think ???
    Dec 2009
    Canada
    Hi Acetronics,
    With this plugin i still have
    • PICBASIC PRO™ (None found)
    in the select compiler page although Microcode studio does not see any problem....
    OK, then will just wait for MPLABX release version..
    Best regards
    Sep 2007
    Waco, Texas
    Hello All-
    I am trying to work with PBP3 and MPLAB X and I do see the Toolchain refrence PicBasic Pro but I cannot seem to do anything....... is there a online tutorial for PBP and MPLAB X? I have Googled for several hours but nothing has turned up.
    Can someone point me to the map so I can find an answer?
    Regards and Happy New Year!
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Oct 2010
    In case there were more people with issues getting PBP3 working with MPLABX I have some more information. Presuming you have Already installed the toolchain plugin into MPLABX, then you need to also goto TOOLS then OPTIONS then EMBEDDED then ADD. You should see the PBP compiler listed. Add it, then make it your default compiler. Presto! Make a new project and you should now be able to select PBP3 properly.
    Jun 2004
    Michigan
    Did all that and pbp3 shows up as compiler choice.
    Made blink.x project.
    Added blink.pbp to project.
    Did clean build.
    Get: Cannot run program "C:\Program" (in directory "C:\PBP3\EXAMPLES\blink.X"
    Any other tips?
    Chuck Hellebuyck
    Electronic Products
    http://www.elproducts.com
    [email protected]
