How to concatenate a HEX BCD value with a string as a new string?
Results 1 to 4 of 4
    Default Re: How to concatenate a HEX BCD value with a string as a new string?
    It should, try it. Just make sure file1 is declared big enough to hold the string.
    Mar 2009
    Colorado
    Thanks, Henrik...it looks like it worked. The way I tested it was to write the file1 array elements to EEPROM so I could see each letter after the program ran and whether the result from the ARRAYWRITE statement did what I wanted. It did.
    Now I have a follow on problem that maybe you can advise me on.
    I had to build this text file name so I could use it in a SEROUT2 command over a serial interface to a ConnectOne iWiFi MiniSocket module that is connected to my microcontroller PIC 16F886. The iWiFi module requires AT+i statements to send it FTP commands in a specific format. I think that this command should open the filename "15hour.txt" via this FTP command, however so far I haven't been able to see the FTP'd data show up in the file named by the filename . Any suggestions?
    SEROUT2 TX,84,["AT+iFSTO:000,",STR filename\10,$d,$a]
