Measuring duty cycle when it can be 0 to 100.
Results 1 to 4 of 4
    Default Measuring duty cycle when it can be 0 to 100.
    I have this measuring duty cycle bit down pretty good until the duty is either 0 or 100. For example, using CCP and signal is high all the time (100%) won't the timers both overflow when looking for high to low and low to high? Whats a good route to take to test for either condition? We went to watch the Parade of Lights last night in Denver so my brain is still half frozen, maybe I am missing something obvious.
    One thing is the frequency is a constant too.
    Default Re: Measuring duty cycle when it can be 0 to 100.
    you mean 0 to 255 ?
    No I have in incoming signal that has a duty cycle from 0 to 100%. The signal is running a motor. 0% duty cycle is motor not running at all. 100% duty cycle the motor is running full speed. I want to measure the duty cycle controlling the motor. Frequency is 125 hz for this incoming PWM. When the PWM is between 0 and 100% duty cycle I am good to go. When it is either 0(low all the time) or 100(high all the time) the overflow occurs.
    Smile Re: Measuring duty cycle when it can be 0 to 100.
    Hi, Tobias
    your signal lasts 8 ms @ 125 hz ...
    so , just measure time ...
    if signal high > 8 ms then it's 100% ...
    if signal low > 8 ms then it's 0% ...
    Was VERY cold in Denver, last night !!! don't you think ?
