I am trying to read both channels form a LTC1865 16 bit ADC. It is a pin for pin replacement for the LTC1298 chip but the commands are different .
JTCullins, It sound pretty straight forward to me...
The LTC1864 conversion cycle begins with the rising edgeof CONV. After a period equal to tCONV, the conversion isfi nished. If CONV is left high after this time, the LTC1864goes into sleep mode drawing only leakage current. On thefalling edge of CONV, the LTC1864 goes into sample modeand SDO is enabled. SCK synchronizes the data transferwith each bit being transmitted from SDO on the fallingSCK edge. The receiving system should capture the datafrom SDO on the rising edge of SCK. After completing thedata transfer, if further SCK clocks are applied with CONVlow, SDO will output zeros indefi nitely.
It does oparate differently from the LTC1298 but I don't see the problem.. Just take the CONV line high for a period of time then take it low, after which you shift in the data... It's just that easy.....
EN82fn
Thank you for your response.
Actually I am using the LTC1865 . It is full duplex which means it accepts commands and sends data at the same time. I can get stuff out' I would not call it data but bits coming out reading CH1 but never CH0. I am sure it is something simple that I am not seeing. I have used the LTC1298 and it works great and is very rugged chip, however it is only 12 bit and I need 16 bits.
JT, You MUST send the channel information as soon as you drop the CONV line low. acording to the spec. Are you doing this? Like you said, this is a full duplex device and as such it will require you to send the channel information along with the first 2 clock pulses as well as receive the first 2 bits of the result which are the bits 15 and 14.
EN82fn
Thanks Dave, I was busy yesterday build boards for an on going project. I will give it a shot today.
I would like to have used the shiftout and Shiftin as I did on the 1298 but I guess I need to bit bang it myself.
I hope it will be fast enough.
Thank you for your help
JT
JT, Personally I would use a SPI interface if your chip of choice has one...
EN82fn
