How do you drive a Serial LCD?
Results 1 to 20 of 20
    Aug 2005
    Michigan, USA
    Default How do you drive a Serial LCD?
    How do you drive a Serial LCD in PBP? Do you use the DEBUG command? Also, do Serial LCDs recognize the 0xFE character to set the LCD "RS" bit to 0 for the next character?
    TIA Gentlemen. Happy Holidays everyone.
    Cheerful regards, Mike
    Default Re: How do you drive a Serial LCD?
    Hi Mike,
    You can use DEBUG, SEROUT, SEROUT2 or HSEROUT. DEBUG generates the smallest code but is the least flexible one. As for recognizing 0xFE you'd have to check the datahseet/manual for the particular serial LCD you're using regarding how you switch between command and data. I imagine they can have slightly different features/command sets depending on manufacturer etc.
    This data sheet has a Basic Stamp example
    http://www.seetron.com/docs/bpp440mnl.pdf
    Aug 2005
    Michigan, USA
    Hi Henrik,
    But which of those functions would provide the most compatibility with the LCDOUT command? I assumed you would use DEBUG because it has data formatting options which are similar to LCDOUT.
    What I'm trying to do is make a Serial LCD Backpack that would easily support PBP and I thought that if my LCD Backpack recognized the 0xFE character it might make it easier to take an existing PBP program and convert it for use with the Serial LCD Backpack by swapping out the LCDOUT keyword with the DEBUG keyword (leaving instruction operands intact).
    Aah, you're MAKING one, OK.
    That would be DEBUG, SEROUT2 and HSEROUT as they all support the same modifiers such as DEC, SDEC etc. DEBUG produces smaller code since its parameters are set at compiletime (with DEFINEs) while SEROUT2 uses runtime setable parameters.
    For your backpack, select a PIC with USART and use HSERIN to capture the incomming data. Check mackrackits link as well!
    Aug 2005
    Michigan, USA
    Henrik,
    Thank you! That's the info' I was looking for.
    For your backpack, select a PIC with USART and use HSERIN to capture the incoming data.
    This version of my Serial LCD Backpack uses a 12F683 and an assembly language program. While building a prototype board a couple weeks ago for the new 8 pin, 14 pin, and 20 pin "enhanced" mid-range devices, I decided to add my old Serial LCD Backpack circuit onto the extra space at the bottom of the board (see silkscreen below). In the picture below, a 16F1823 is driving the backpack circuit at 57600 baud (one pin "overhead" on the 16F1823).
    I checked the link (thanks Dave) but it's not really what I was looking for.
    Thanks guys... Happy Holidays!
    OOPs my bad posted what Dave did. It does use the LCDOUT syntax though . . .
    Oct 2009
    Utah, USA
    Hey Mike K8LH,
    Nice looking board... I have several of the 12F683 PIC's laying around and a couple of LCD's that they would go nicely with... I am amazed that you had enough pins to drive the LCD and receive serial data.
    would you be willing to share your schematic and code??
    Thanks in advance
    Dwight
    Aug 2005
    Michigan, USA
    Hi Dwight,
    I attached the schematic below but I'm afraid the interface in its present form is not very PBP friendly. It was the only way I knew of at the time to control six (6) pins on an LCD with only five (5) PIC output pins. That means you have to drive the display by sending two serial bytes for each LCD byte, each serial byte containing four data bits and an RS bit.
    The new design that I'm working should be done soon. It uses full eight bit bytes and recognizes the $FE character (for toggling an RS flag).
    Regards...
    Oct 2009
    Utah, USA
    Thanks Mike,
    That was quite innovative of you to use the incomming data to both talk to the PIC and control the RS line of the LCD!!
    nice work.
    So is your new design going to use a differend PIC with more I/O pins??
    Dwight
    Dwight
    Aug 2005
    Michigan, USA
    I'm upgrading the interface that uses the 8 pin PIC and actually studying another two slightly more advanced designs.
    If you're interested, I've attached the source (assembler) for the 12F635 backpack as well as the source (also assembler) for the 16F1823 on that prototype board. This is the old software and, as I mentioned, probably not very useful for PBP users who are used to having all those wonderful LCD output formatting capabilities.
    Happy Holidays! Mike
    Aug 2005
    Michigan, USA
    Hi Dwight (and gang),
    If you're interested... I just finished testing the upgrade to the 8-pin PIC serial LCD interface and it works great. The mod involved adding an RC integrator/filter (10K + 330pF) between the GP0/D4 pin and the LCD RS pin. Now I can drive all six LCD control pins directly from the little 8-pin PIC which means I can collect serial data, analyze it, and write data to the LCD display any way I want. In short, you should be able to feed the serial interface using the DEBUG, SEROUT2 or HSEROUT commands with all of the same formatting parameters you're using now with the LCDOUT command. I'm pretty geeked (yes, I'm a nerd - LOL).
    If anyone is interested, I'll start a new thread in the 'schematic' sub-forum after characterizing and testing the firmware. The only real advantages I can think of for this interface is its size (very small footprint on a project board when using the 2x5 header for a MikroE LCD Adapter board) and its ability to drive four lines of a switch matrix (one additional pin on the host can read four switches, an encoder, etc.).
    Cheers, Happy Holidays, Mike
    Aug 2005
    Michigan, USA
    Drawing of the updated backpack hardware...
    Mentor, Ohio
    Hi Mike,
    Mind if I ask what program you are using to illustrate your drawings?
    BobK
    Aug 2005
    Michigan, USA
    Greetings BobK.
    The drawings were made using the drawing tools in Excel...
    The paper silkscreen on the Radio Shack prototyping board was a printout of the silkscreen layer from DipTrace. The paper silkscreen is laminated with plastic tape and glued onto the board.
    Aug 2005
    Michigan, USA
    Better late than never? Here's firmware for the 12F683 version of the serial backpack.
    ;   Filename: ezLCD v3 (12F683).asm                               *
    ;     Author: Mike McLaren, K8LH                                  *
    ;    (C)2010: Micro Application Consultants, All Rights Reserved  *
    ;       Date: 08-Dec-11  (rev:111210.0637z)                       *
    ;   K8LH 12F683 serial HD44780 LCD 4-bit interface experiment     *
    ;   8-bit test code.  this interface traps a 0xFE character and   *
    ;   writes the character immediately following it to the LCD as   *
    ;   a command character (RS = 0)                                  *
    ;      MPLab: 8.80    (tabs=8)                                    *
    ;      MPAsm: 5.43                                                *
        #include <p12f683.inc>
        list st=off
        errorlevel -302
        radix   dec
        __config  _FCMEN_OFF&_IESO_OFF&_MCLRE_OFF&_WDT_OFF&_INTRC_OSC_NOCLKOUT
    ;--< variables >---------------------------------------------------
    datahi  equ     0x40            ; shadow for 1st nibble
    datalo  equ     0x41            ; shadow for 2nd nibble
    temp    equ     0x42            ; low level LCD routines
    delayhi equ     0x43            ;
    rsflag  equ     0x44            ;
    ;--< constants >---------------------------------------------------
    ;  bit time (cycles) used to sample a serial bit stream
    ;    9600 baud, 208 (208.3) cycles, 0.16% bit rate error
    ;   19200 baud, 104 (104.2) cycles, 0.16% bit rate error
    ;   57600 baud,  35 ( 34.7) cycles, 0.80% bit rate error
    clock   equ     8               ; 8 MHz clock
    usecs   equ     clock/4         ; cycles/usec multiplier
    msecs   equ     clock/4*1000    ; cycles/msec multiplier
    bRate   equ     57600           ; baudrate 9600, 19200, or 57600
    bTime   equ     (usecs*10000000/bRate+5)/10
                                    ; bTime = 208, 104, or 35 cycles
    #define D4      0               ; GP0 -> LCD 'D4'
    #define D5      1               ; GP1 -> LCD 'D5'
    #define D6      2               ; GP2 -> LCD 'D6'
    #define SerPin  GPIO,3          ; GP3 -> Serial Input
    #define D7      4               ; GP4 -> LCD 'D7'
    #define E       5               ; GP5 -> LCD 'E'
    #define RS      D4              ; RS 'rc' integrator output
    ;--< macros >------------------------------------------------------
    ;  inDlyCy() in-line delay macro, range 0..1023 cycles,
    ;  produces 0 to 6 instructions.
    inDlyCy macro   pTime
            local   dloop
          if pTime > 3
            movlw   (pTime)/4-1     ;
    dloop   addlw   -1              ;
            bc      dloop           ;
          if pTime%4 & 1
            nop                     ; 1 cycle
          if pTime%4 & 2
            goto    $+1             ; 2 cycles
    ;  K8LH DelayCy() subsystem macro generates four instructions
    DelayCy macro   cycles          ; 11..327690 cycle range
        if (cycles<11)|(cycles>(5*65536+10))
            error " DelayCy range error "
            movlw   high((cycles-11)/5)+1
            movwf   delayhi
            movlw   low ((cycles-11)/5)
            call    uDelay-((cycles-11)%5)
    ;   Reset Vector                                                  *
            org     0x0000
    v_reset
            clrf    STATUS          ;				  |B0
            goto    Main            ;                                 |B0
    ;   Interrupt Vector                                              *
            org     0x0004
    v_int
    ;  using IOC interrupt on start bit leading edge
            inDlyCy(bTime/2-4)      ; half bit time minus 4 cycles    |B0
            movlw   1<<E            ; preset E bit                    |B0
            movwf   datahi          ;                                 |B0
            movwf   datalo          ;                                 |B0
    ;  collect lo nibble in 'datalo' (LCD data bits b0..b3)
    bit0    inDlyCy(bTime-3)        ;                                 |B0
            btfsc   SerPin          ; bit = 0?  yes, skip, else       |B0
            bsf     datalo,D4       ; set LCD D4 shadow bit           |B0
    bit1    inDlyCy(bTime-2)        ;                                 |B0
            bsf     datalo,D5       ; set LCD D5 shadow bit           |B0
    bit2    inDlyCy(bTime-2)        ;                                 |B0
            bsf     datalo,D6       ; set LCD D6 shadow bit           |B0
    bit3    inDlyCy(bTime-2)        ;                                 |B0
            bsf     datalo,D7       ; set LCD D7 shadow bit           |B0
    ;  collect hi nibble in 'datahi' (LCD data bits b4..b7)
    bit4    inDlyCy(bTime-2)        ;                                 |B0
            bsf     datahi,D4       ; set LCD D4 shadow bit           |B0
    bit5    inDlyCy(bTime-2)        ;                                 |B0
            bsf     datahi,D5       ; set LCD D5 shadow bit           |B0
    bit6    inDlyCy(bTime-2)        ;                                 |B0
            bsf     datahi,D6       ; set LCD D6 shadow bit           |B0
    bit7    inDlyCy(bTime-2)        ;                                 |B0
            bsf     datahi,D7       ; set LCD D7 shadow bit           |B0
    ;     if(datahi == 0x0F)        // if data == 0xF0..0xFF
    ;     { datahi.E = 0;           // don't write LCD (E bit off)
    ;       datalo.E = 0;           // don't write LCD (E bit off)
    ;     gpio = rsflag;            // charge or drain RS cap
    ;     delay_us(3);              //
    ;     gpio = datahi;            // setup D4..D7 and E=1
    ;     gpio.E = 0;               // E = 0 (write LCD)
    ;     delay_us(3);              //
    ;     gpio = datalo;            // setup D4..D7 and E=1
    ;     rsflag ^= 1<<RS;          // toggle rs flag
    ;     if(datahi.E)              // if not 0xFE character
    ;       rsflag = 1<<RS;         // reset rs flag (RS=1)
    wrhi
            movf    rsflag,W        ; the RS bit flag & mask          |B0
            movwf   GPIO            ; charge or drain RS cap          |B0
            movlw   b'00110111'     ; mask for datahi = 0x0F          |B0 --
            xorwf   datahi,W        ; is data == 0xF0..0xFF?          |B0 --
            skpnz                   ; no, skip, else                  |B0 --
            bcf     datahi,E        ; don't write LCD                 |B0 --
            bcf     datalo,E        ; don't write LCD                 |B0 --
            movf    datahi,W        ; get data 7..4 bits              |B0
            movwf   GPIO            ; setup D4..D7, E=1               |B0
            bcf     GPIO,E          ; E = 0 (write LCD)               |B0
    wrlo
            movlw   1<<RS           ;                                 |B0 --
            xorwf   rsflag,F        ; toggle RS flag & mask           |B0 --
            btfsc   datahi,E        ; if datahi not 0x0F              |B0 --
            iorwf   rsflag,F        ; reset RS flag & mask (RS=1)     |B0 --
            goto    $+1             ;                                 |B0 --
            movf    datalo,W        ; get data 3..0 bits              |B0
            movwf   GPIO            ; setup D4..D7, E = 1             |B0
    stop
            inDlyCy(bTime-24)       ; during middle of stop bit       |B0
            movf    GPIO,W          ; clear IOC mismatch              |B0
            bcf     INTCON,GPIF     ; clear IOC interrupt flag        |B0
            retfie                  ;                                 |B0
    ;  main                                                           *
    ;  void main()
    ;    cmcon0 = 7;                // comparator off
    ;    gpio = 0;                  // clear gpio output latches
    ;    trisio = 0b00001000;       // gp3 input, others outputs
    ;    osccon = 0b01110000;       // setup intosc for 8 MHz
    ;    while(osccon.HTS == 0);    // wait for osc stable
    Main
            movlw   b'00000111'     ;                                 |B0
            movwf   CMCON0          ; comparator off                  |B0
            clrf    GPIO            ; clear GPIO output latches       |B0
            bsf     STATUS,RP0      ; bank 1                          |B1
    ;       clrf    ANSEL           ; no analog, all digital          |B1
            movlw   b'00001000'     ; GP3 input, all others outputs   |B1
            movwf   TRISIO          ;                                 |B1
            movwf   IOCA            ; enable IOC for GP3 'SerPin'     |B1
            movlw   b'01110000'     ;                                 |B1
            movwf   OSCCON          ; 8-mhz INTOSC system clock       |B1
    stable  btfss   OSCCON,HTS      ; oscillator stable?              |B1
            goto    stable          ; no, branch, else                |B1
    ;  HD44780 "initialize by instruction" for 4-bit interface mode
            bcf     STATUS,RP0      ; bank 0                          |B0
            DelayCy(50*msecs)       ; LCD 50 msec 'power up' reset    |B0
            movlw   0x03            ; hi nibble of "8-bit" command    |B0
            call    PutNyb          ; step 1 (send nibble only)       |B0
            DelayCy(4*msecs)        ; required 4 msec delay           |B0
            movlw   0x03            ;                                 |B0
            call    PutNyb          ; step 2 (send nibble only)       |B0
            DelayCy(160*usecs)      ; required 160-us delay           |B0
            movlw   0x03            ;                                 |B0
            call    PutNyb          ; step 3 (send nibble only)       |B0
            movlw   0x02            ; hi nibble of "4-bit" command    |B0
            call    PutNyb          ; select 4-bit interface mode     |B0
    ;  now in 4-bit interface mode. ok to send full bytes.
            movlw   0x28            ; 4-bit, 2-lines, 5x7 font        |B0
            call    PutCmd          ; send "function set" command     |B0
            movlw   0x0C            ; display on, cursor & blink off  |B0
            call    PutCmd          ; send "display on/off" command   |B0
            movlw   0x06            ; cursor inc, shift off           |B0
            call    PutCmd          ; send "entry mode set" command   |B0
            movlw   0x01            ; clear display (1.53-msecs)      |B0
            DelayCy(1530*usecs)     ; 1.53 msec delay for "clear"     |B0
    ; // setup RA3 'SerPin' for interrupt-on-change
    ;    rsflag = 1<<RS;            // set RS flag & mask
    ;    while(SerPin == 0);        // wait for hi level on GP3
    ;    temp = gpio;               // clear any mismatch condx
    ;    intcon.RAIF = 0;           // clear IOC interrupt flag
    ;    ioca.IOCA3 = 1;            // eanble IOC for GP3 'SerPin'
    ;    intcon.GIE = 1;            // enable global interrupts
    ;    while(1);                  // loop forever
            movlw   1<<RS           ;                                 |B0
            movwf   rsflag          ; set RS flag & mask (RS=1)       |B0
            btfss   SerPin          ; stop state? yes, skip, else     |B0
            goto    $-1             ; loop (wait)                     |B0
            movf    GPIO,W          ; clear GPIO mismatch condition   |B0
            bsf     INTCON,GIE      ; enable global interrupts        |B0
            bsf     INTCON,GPIE     ; enable 'IOC' interrupts         |B0
    loop
            goto    loop            ; loop forever                    |B0
    ;  low level lcd subroutines                                      *
    PutCmd                          ; entry point for "cmd" data
            clrc                    ; RS = 0 (command)                |B?
            skpnc                   ; skip unconditionally            |B?
    PutDat                          ; entry point for "dat" data
            setc                    ; RS = 1 (data)                   |B?
            banksel temp            ; bank 0                          |B0
            movwf   temp            ; save WREG data byte             |B0
            swapf   temp,W          ;                                 |B0
            call    PutNyb          ; send hi nybble                  |B0
            swapf   temp,W          ;                                 |B0
            call    PutNyb          ; send lo nybble                  |B0
            DelayCy(50*usecs)       ; required between writes         |B0
            return                  ;                                 |B0
    PutNyb
            movwf   temp            ;                                 |B0
            bcf     GPIO,RS         ; RS = 0 (discharge RS cap)       |B0
            skpnc                   ; RS = 0?  yes, skip, else        |B0
            bsf     GPIO,RS         ; RS = 1 (charge RS cap)          |B0
            movlw   1<<E            ;                                 |B0
            btfsc   temp,0          ;                                 |B0
            iorlw   1<<D4           ;                                 |B0
            btfsc   temp,1          ; b1 = 0?  yes, skip, else        |B0
            iorlw   1<<D5           ;                                 |B0
            btfsc   temp,2          ; b2 = 0?  yes, skip, else        |B0
            iorlw   1<<D6           ;                                 |B0
            btfsc   temp,3          ; b3 = 0?  yes, skip, else        |B0
            iorlw   1<<D7           ;                                 |B0
            movwf   GPIO            ; LCD D4..D7 = data1, E = 1       |B0
            bcf     GPIO,E          ; E = 0                           |B0
            return                  ;                                 |B0
    ;  K8LH DelayCy() 16-bit uDelay subroutine                        ~
            nop                     ; entry for (delay-11)%5 == 4     |B0
            nop                     ; entry for (delay-11)%5 == 3     |B0
            nop                     ; entry for (delay-11)%5 == 2     |B0
            nop                     ; entry for (delay-11)%5 == 1     |B0
    uDelay  addlw   -1              ; subtract 5 cycle loop time      |B0
            skpc                    ; borrow? no, skip, else          |B0
            decfsz  delayhi,F       ; done?  yes, skip, else          |B0
            goto    uDelay          ; do another loop                 |B0
            return                  ; return with C = Z = 0           |B0
    Thanks Mike ! Always another way to get there, I like smaller, cheaper PIC too.
    I admire your courage to do this in assembly!
    Jan 2006
    Istanbul
    Same here.
    This is a very nice work and, even more, Mike shares it here.
    Thanks to Mike from this part of the world.
