How do you drive a Serial LCD?
Results 1 to 20 of 20
    Aug 2005
    Michigan, USA
    Default How do you drive a Serial LCD?
    How do you drive a Serial LCD in PBP? Do you use the DEBUG command? Also, do Serial LCDs recognize the 0xFE character to set the LCD "RS" bit to 0 for the next character?
    TIA Gentlemen. Happy Holidays everyone.
    Cheerful regards, Mike
    Default Re: How do you drive a Serial LCD?
    Hi Mike,
    You can use DEBUG, SEROUT, SEROUT2 or HSEROUT. DEBUG generates the smallest code but is the least flexible one. As for recognizing 0xFE you'd have to check the datahseet/manual for the particular serial LCD you're using regarding how you switch between command and data. I imagine they can have slightly different features/command sets depending on manufacturer etc.
    This data sheet has a Basic Stamp example
    http://www.seetron.com/docs/bpp440mnl.pdf
    Aug 2005
    Michigan, USA
    Hi Henrik,
    But which of those functions would provide the most compatibility with the LCDOUT command? I assumed you would use DEBUG because it has data formatting options which are similar to LCDOUT.
    What I'm trying to do is make a Serial LCD Backpack that would easily support PBP and I thought that if my LCD Backpack recognized the 0xFE character it might make it easier to take an existing PBP program and convert it for use with the Serial LCD Backpack by swapping out the LCDOUT keyword with the DEBUG keyword (leaving instruction operands intact).
    Aah, you're MAKING one, OK.
    That would be DEBUG, SEROUT2 and HSEROUT as they all support the same modifiers such as DEC, SDEC etc. DEBUG produces smaller code since its parameters are set at compiletime (with DEFINEs) while SEROUT2 uses runtime setable parameters.
    For your backpack, select a PIC with USART and use HSERIN to capture the incomming data. Check mackrackits link as well!
    Aug 2005
    Michigan, USA
    Henrik,
    Thank you! That's the info' I was looking for.
    For your backpack, select a PIC with USART and use HSERIN to capture the incoming data.
    This version of my Serial LCD Backpack uses a 12F683 and an assembly language program. While building a prototype board a couple weeks ago for the new 8 pin, 14 pin, and 20 pin "enhanced" mid-range devices, I decided to add my old Serial LCD Backpack circuit onto the extra space at the bottom of the board (see silkscreen below). In the picture below, a 16F1823 is driving the backpack circuit at 57600 baud (one pin "overhead" on the 16F1823).
    I checked the link (thanks Dave) but it's not really what I was looking for.
    Thanks guys... Happy Holidays!
    OOPs my bad posted what Dave did. It does use the LCDOUT syntax though . . .
    Oct 2009
    Utah, USA
    Hey Mike K8LH,
    Nice looking board... I have several of the 12F683 PIC's laying around and a couple of LCD's that they would go nicely with... I am amazed that you had enough pins to drive the LCD and receive serial data.
    would you be willing to share your schematic and code??
    Thanks in advance
    Dwight
    Aug 2005
    Michigan, USA
    Hi Dwight,
    I attached the schematic below but I'm afraid the interface in its present form is not very PBP friendly. It was the only way I knew of at the time to control six (6) pins on an LCD with only five (5) PIC output pins. That means you have to drive the display by sending two serial bytes for each LCD byte, each serial byte containing four data bits and an RS bit.
    The new design that I'm working should be done soon. It uses full eight bit bytes and recognizes the $FE character (for toggling an RS flag).
    Regards...
