Read cursors position on LCD?
Results 1 to 5 of 5
    lab310's Avatar
    lab310 Guest
    Default Read cursors position on LCD?
    Is it possible to find current cursor possition on LCD (standard Hitachi controller) ? After reading LCD data sheet , couldnt find any address that holds cursors pos. , but maybe I'm wrong.
    Yes, the operation is called "Read Busy Flag and Address".
    You need connection of the R/W line.
    Set R/W=1 (usually set 0), set RS=0, Busy Flag is returned in DB7, Address Counter is returned in DB0 thru DB6. There is no equivallent PICBasic instruction. LCDIN sets R/W=1 and RS=1. Close, but no cigar. LCDIn and LCDOut don't check the Busy Flag, they just use blind timing.
    I normally have the PIC keep track of the Cursors position - LCD's aren't that big, so how hard is it to lose your Cursor?
    lab310's Avatar
    lab310 Guest
    Yes , found that info too, but I'm using 4-bit connection to LCD so this won't work. No one mentions if this is possible when using 4bit instead of 8.
    I have complex manu map, and could to some things much easier if I knew possition of cursor .
    Well.... you could try connecting the R/W line, assign a 2nd pin to the RS bit, put it and the existing RS pin line thru an AND gate (two Diodes and a Resistor would suffice) to the LCD, drive the new RS bit pin Low (forcing LCD RS Low) and then issue an LCDIN instruction... Do you feel lucky?
    Feb 2004
    Germany
    Quote Originally Posted by Melanie
    Lab,
    do you really want to pay this price?
    As Melanie already said, it is the PIC controlling the LCD, so how can you loose the cursor position?
    regards
    Ralph
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. LCD will not start
