18F2620 pbp3 example config please
Results 1 to 23 of 23
    Default Re: 18F2620 pbp3 example config please
    What exactly does that mean, what warnings do you get and from where do you get them?
    Your code compiles and assembles fine with PBP 3.0.7.4 & MPASM 5.45. Are you using the standalone software for the PICKit2 and is it THAT software that gives you these misterious warnings?
    Make a "Complete" set of configs for any chip with ease.
    meCONFIG
    http://support.melabs.com/content/563-meCONFIG
    Yes the pickit 2 software states when programming that some configuration bits not in acceptable condition. It still programs and works fine but is disconcerting for users.
    That new meconfig software is interesting I see quite a few bits/parameters I have ignored/did not know about. :?
    The PICkit software expects to see a value for EVERY configuration word.
    The latest versions of PBP3 do create default values for all of them.
    But when you use the #CONFIG block, it overrides all of the defaults, and you should include a "Complete" set for use with the PICkit programmers.
    Like you said, it will program and work ... but a complete set of configs will eliminate that warning.
    melabs have a neat config editor meCONFIG ITS WORTH DOWNLOADING and free , or check out the DEVICE_REFERENCE folder in your pbp3 installed directory
    but for now try this
      CONFIG  OSC = INTIO67
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BOREN = OFF
      CONFIG  BORV = 3
      CONFIG  WDT = ON
      CONFIG  WDTPS = 512
      CONFIG  CCP2MX = PORTC
      CONFIG  PBADEN = OFF
      CONFIG  LPT1OSC = OFF
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    ps not sure why your asking for PIC18F4520 config info in a 18F2620 thread why not start a new one ?
    the correct syntax and available config word (fuse) settings are available in the pbp3 device_reference folder
    File: PIC18F4520.INFO
    Available configuration settings for PIC18F4520:
    ;  Oscillator Selection bits
    ;    CONFIG OSC = INTIO7     ;Internal oscillator block, CLKO function on RA6, port function on RA7
    ;    CONFIG OSC = INTIO67     ;Internal oscillator block, port function on RA6 and RA7
    ;    CONFIG OSC = RCIO6     ;External RC oscillator, port function on RA6
    ;    CONFIG OSC = HSPLL     ;HS oscillator, PLL enabled (Clock Frequency = 4 x FOSC1)
    ;    CONFIG OSC = ECIO6     ;EC oscillator, port function on RA6
    ;    CONFIG OSC = EC     ;EC oscillator, CLKO function on RA6
    ;    CONFIG OSC = RC     ;External RC oscillator, CLKO function on RA6
    ;    CONFIG OSC = HS     ;HS oscillator
    ;    CONFIG OSC = XT     ;XT oscillator
    ;    CONFIG OSC = LP     ;LP oscillator
    Assembler uses columns, leave the same spacing as in the INC file.
