18F2620 pbp3 example config please
Results 1 to 23 of 23
    Default Re: 18F2620 pbp3 example config please
    Thanks for the guidance here is my new 18F2620 config.
    '------------------------------ New General 18F2620 configuration --------------------------
    '#CONFIG
    ' __CONFIG _CONFIG1H, _OSC_INTIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    ' __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOREN_OFF_2L
    ' __CONFIG _CONFIG2H, _WDT_OFF_2H
    ' __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_OFF_3H
    ' __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    '#ENDCONFIG
    'DEFINE OSC 8   'Set PicBasic Pro processor speed to 8 Mhz
    'OSCCON = %01110110   'Internal 8 mhz Osc and stable
    'CMCON  = %00000111  'Comparators Off
    'T1CON  = %00110000  '$30 = Prescaler 1:8, TMR1 OFF
    'TRISA = %00001011   'SET PORTA0, A1 & A3 AS INPUTS, REST AS OUTPUTS
    'TRISB = %00000000   'SET PORTB AS OUTPUTS
    'TRISC = %10010000   'SET PORTC AS OUTPUTS EXCEPT PORT C4 & C7
    'ADCON0 = %00000001  'SETUP ADC & ENABLE ADC MODULE on AD0
    'ADCON1 = %00001110  'SETUP ADC SET REFV to VDD & VSS AN0
    'ADCON2 = %00100010  'SETUP ADC FOSC/32 LEFT JUSTIFY TAD 8
    Below is my working old 16F886 config. Any glaring errors in the above? I'm just swapping chips and I want all functions to remain the same.
    '------------------------------ General 16F886 configuration --------------------------
     __CONFIG _CONFIG1, _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_OFF & _WDT_OFF &
    _INTRC_OSC_NOCLKOUT
     __CONFIG _CONFIG2, _WRT_OFF & _BOR21V
    OSCCON = %01110101   'Internal 8 mhz Osc and stable
    CM1CON0 = 0    'Comparator Off
    CM2CON0 = 0    'Comparator Off
    ANSEL  = %00000001  'SET INPUT AN0 AS ANALOG INPUT
    ANSELH = %00000000              'Disable PortB AD
    ADCON0 = %10000001  'SETUP ADC CONVERTER MODULE FOSC/32 & ENABLE ADC MODULE on AD0
    ADCON1 = %00000000  'SETUP ADC LEFT JUSTIFY SET REFV to VDD & VSS
    Thanks Peter
    I moved to a new pic to gain memory space but the same program compiled for the new pic is nearly twice the size as the 16F886 version :?
    Why is that and can I get some memory back. I don't need 18F longs for instance and that is already disabled in the compiler.
    My guess is that it's because on the 16 series (10 & 12 too I believe) the memory is "measured" in WORDS (14-bit words if I'm not mistaken) while on the 18 series it's measured in BYTES. So I don't think your program is actually getting twice as big, it's just displaying the size of it in BYTES instead of in WORDS.
    Default Still get pickit2 config bits warning
    I still get the some config bits warning with pickit 2.
    I can't see why?
    '------------------------------ General 18F2620 configuration --------------------------
     __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    OSCCON = %01110000 		'Internal 8 mhz Osc
    WDTCON = %00010101		'Set watchdog Timer for 1 second
    CVRCON = %00000000		'CvRef Powered Down
    CCP1CON= %00001100		'CCP1 Module PWM Mode
    CCP2CON= %00000000		'CCP2 Module Disabled
    HLVDCON= %00000000		'HLVCON Disabled
    ADCON0 = %00000001		'SETUP ADC & ENABLE ADC MODULE on AN0
    What exactly does that mean, what warnings do you get and from where do you get them?
    Your code compiles and assembles fine with PBP 3.0.7.4 & MPASM 5.45. Are you using the standalone software for the PICKit2 and is it THAT software that gives you these misterious warnings?
    Make a "Complete" set of configs for any chip with ease.
    meCONFIG
    http://support.melabs.com/content/563-meCONFIG
    Yes the pickit 2 software states when programming that some configuration bits not in acceptable condition. It still programs and works fine but is disconcerting for users.
    That new meconfig software is interesting I see quite a few bits/parameters I have ignored/did not know about. :?
