PULSIN - Logic Level Voltage Transiion
Results 1 to 6 of 6
    Dec 2005
    Default Re: PULSIN - Logic Level Voltage Transiion
    Table 10.1 and Table 26.3 tell you what you need. You might also try measuring between rising edges to see if the period is what you think it is.
    Sep 2010
    Thanks Dave,
    I will try your recommendations when I get to work tomorrow. Looking at the rise time 9 ns today makes me think that that is probably not the problem. Takes a lot of 9 nsec to add up to 3 usec I am going to look at it closely so at least I understand more about what is going on and the effects of rise/fall times in general. Looks like you have a bunch of stuff I need to look at on your web site. So much to do, so little time. Thanks, again. CC
    Hi, CC
    @ First, you have to undersand how Pulsin works ...
    1) input is set to an ... Input !
    2) software counter is initialised and waits for the required edge to come ...
    3) leading Edge detected ... the counter ... counts ( unbelievable, eh ? )
    4) trailing edge detected ... counter stops counting ( see 3 )
    5) counter value is transferred to the target variable.
    from that ....
    1) you need a little delay between the Pulsin command and the effective counting can start ( presetting delay )
    2) you need a little delay between the counting is finished and a new command to be executed ...
    after that ...
    WHILE TRIGGER=1:WEND 'MAKE SURE I DON'T START IN THE MIDDLE OF A PULSE
    is not useful ... as the pulsin command triggers ... on a level CHANGE ...
    If measuring very short times ... your result will be either 3 or 4 ( example ) ... and precision will be VERY, VERY bad ...
    So, ... it appears this way of measuring is " not so good " and you'd much better use the CCP module,in capture mode, with the 1/16 predivisor ... or if more samples required, a CD 4520 as an external 1/100 divider.
    AND ... YES, you've hit the Basic languages functions ( not only PBP ) limitations .... ... so, you have to directly drive the Pic registers !!!
    Sep 2010
    Alain,
    Thanks you very much for the clear explaination of how the pulsin function works! I will investigate the CCP capture mode method.
    Thanks, again.
    CC
