LCD freezing problem with interrupts
Results 1 to 10 of 10
    Exclamation Re: LCD freezing problem with interrupts
    Nothing? I've also tried to remove serial commands and CGRAM custom-made characters, same problem.
    Bombay, India
    Default Re: LCD freezing problem with interrupts
    But sometimes when I navigate into this menu (when the AC motor is either on or off), and very randomly, the LCD is "freezing" and after 2 seconds the display is reseted. The 3-phase PWM outputs are not affected at all.
    Now, if I remove only the interrupts (TMR1_INT, INT0, INT2) of my program, this problem doesn't occur.
    Do you get the fault indication? I suspect, you are getting into the FltSub when you say the LCD is frozen.
    You can possibly disable the ocint and the stopint for checking this possibility. Does the LCD still freeze?
    Jan 2006
    Istanbul
    OSC is defined as 40Mhz, where is the config settings?
    which pic is this?
    Completely unrelated to your problem, or perhaps not but anyway.....
    Does these constructs really work? Do they even compile:
    ' FWD/RWD button
    IF PORTC.1=%1 THEN
       IF rot=%0 AND run=%0 AND flag4=%0 THEN rot=%1:flag2=%0:flag4=%1
       IF rot=%1 AND run=%0 AND flag4=%0 THEN rot=%0:flag2=%0:flag4=%1
    I think you need an ENDIF for each of those IF statements.
    ' FWD/RWD button
    IF PORTC.1=%1 THEN
    I've no problems with that (but I've modified this part to something like that):
    if rot=%0 then
    if run=%0 then
    if flag4=%0 then
    rot=%1
    flag2=%0
    flag4=%1
    Yeah, not very readable but take less program space than AND operator. And it works good.
    Quote Originally Posted by sayzer View Post
    which pic is this?
    A special PIC for motor control, it's the PIC18F4431, 10MHz quartz with PLL enabled (so 4*10=40MHz).
    Jan 2006
    Istanbul
    So, while LCDOUT command is being executed, an interrupt is occuring.
    To "test" this, you can disable all interrupts before lcdout command and enable them right after.
    This is just to see.
    But this will definitely effect your motor. It can give you a point anyway.
    Actually I'm not at home so I will try to remove ocint and stopint next friday.
    And no, I'm not getting into Fltsub when my LCD is frozen: in reality, the menu is reseted to the very first position (1: ISENS).
