LCD freezing problem with interrupts
Results 1 to 10 of 10
    Question LCD freezing problem with interrupts
    Hi everyone,
    I've a very weird problem with my program. Here is the source code:
    ' Varidrive "Lite" firmware V2011.00 by DR Electronics
    ' PIC initialization
    DEFINE OSC 40
    DEFINE LCD_DREG PORTD
    DEFINE LCD_EREG PORTB
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_EBIT 6
    DEFINE LCD_RSBIT 7
    DEFINE ADC_BITS 10
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 19200
    DEFINE HSER_SPBRG 129
    ' BAS includes
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "Sine_table.bas"
    ' ADC registers configuration
    ADCON0=%11101
    ADCON1=%10000
    ADCON2=%10000110
    ADCON3=%10000
    ANSEL0=%00001111
    ANSEL1=%0
    ' PCPWM registers configuration
    PTCON0=%10
    PTCON1=%10000000
    PWMCON1=%1
    DTCON=%11
    ' Inverter variables
    ustep var BYTE
    vstep var BYTE
    wstep var BYTE
    uduty var WORD
    vduty var WORD
    wduty var WORD
    freq VAR WORD
    amp var WORD
    copy VAR WORD
    rld VAR WORD
    stor var word
    dum VAR WORD
    dum1 VAR WORD
    dum2 VAR WORD
    bl var BIT
    flag var BIT
    flag1 VAR BIT
    flag2 VAR BIT
    flag3 var BIT
    flag4 var BIT
    flag5 var BIT
    flag6 var BIT
    flag7 var BIT
    flag8 var bit
    flag9 var bit
    a var BYTE
    b var BYTE
    c var word
    d var word
    e var bit
    f var bit
    run VAR BIT
    rot var BIT
    menu var BIT
    mpos VAR BYTE
    isense VAR WORD
    usense VAR WORD
    tsense VAR WORD
    psense var WORD
    idisp var BYTE
    udisp var WORD
    tdisp var BYTE
    maxf var WORD
    minf var WORD
    imax var BYTE
    pwmf var BYTE
    res var BYTE
    flt var BYTE
    lastf var BYTE
    ' Default variables definition
    dum1=5600
    dum2=100
    mpos=1
    a=0
    b=0
    flag=%1
    flag3=%1
    run=%0
    flt=%0
    ' Reading EEPROM
    read 0,rot
    read 1,maxf.HIGHBYTE
    read 2,maxf.LOWBYTE
    read 3,minf.HIGHBYTE
    read 4,minf.LOWBYTE
    read 5,imax
    read 6,pwmf
    read 7,bl
    read 8,lastf
    ' Initial GOSUBs
    GOSUB pwmsub
    GOSUB blsub
    ' Inverter startup
    HIGH PORTD.5
    Hserout ["Varidrive V2011.00|19200 8n1|Maxfreq:",DEC4 maxf,"|Minfreq:",dec4 minf,"|Itrip:",dec3 imax,"|PWMfreq:",dec1 pwmf,"|Backlight:",dec1 bl,"|Lastfault:",dec1 lastf]
    ' Turn LCD on and write custom characters to CGRAM
    LCDOUT $fe,$40,$0,$4,$e,$15,$4,$4,$4,$0
    LCDOUT $fe,$48,$0,$4,$4,$4,$15,$e,$4,$0
    LCDOUT $fe,1
    ' Create interrupt processors
    INT_LIST MACRO
             INT_Handler TMR1_INT,_pwmint,PBP,yes
             INT_Handler INT0_INT,_ocint,PBP,yes
             INT_Handler INT2_INT,_stopint,PBP,yes
             ENDM
             INT_CREATE
    ' Interrupts and timer enable
    @ INT_ENABLE TMR1_INT
    @ INT_ENABLE INT0_INT
    @ INT_ENABLE INT2_INT
    T1CON=%10001
    ' Main program loop
    lp:
    ' Start ADC conversion
    ADCON0.1=%1
    WHILE ADCON0.1=%1:WEND
    ' Store ADC results
    isense.HIGHBYTE=ADRESH
    isense.LOWBYTE=ADRESL
    usense.HIGHBYTE=ADRESH
    usense.LOWBYTE=ADRESL
    tsense.HIGHBYTE=ADRESH
    tsense.LOWBYTE=ADRESL
    psense.HIGHBYTE=ADRESH
    psense.LOWBYTE=ADRESL
    ' Security fault verifications
    IF isense**40000>imax THEN flt=1
    IF usense>880 THEN flt=2
    IF tsense>880 THEN flt=3
    ' Security fault tripping
    IF flt>0 THEN GOTO fltsub
    ' Brake/surge resistor control
    IF usense>800 then
       if run=%1 then high PORTD.7
        LOW PORTD.7
    ' Frequency reference control by potentiometer
    psense=((psense<<6)**maxf)+10
    IF psense<>freq+10 THEN freq=psense:flag=%1
    ' Frequency limits
    IF freq<minf THEN freq=minf
    IF freq>maxf THEN freq=maxf
    ' Recalculations
    IF flag=%1 THEN
       ' Reload timer calculation
       dum=dum1*dum2
       stor=DIV32 freq
       rld=(65535-stor)+8
       ' U/F calculation
       IF freq<=500 THEN
          amp=(freq*131)+35
           amp=65535
      flag=%0
    ' Run
    IF run=%1 THEN
       IF flag1=%0 THEN PWMCON0.6=%1:HIGH PORTD.6:flag1=%1
    ' Stop
    IF run=%0 THEN
       IF flag1=%0 THEN PWMCON0=%0:LOW PORTD.6:flag1=%1
    ' FWD rotation
    IF rot=%1 THEN
       IF flag2=%0 THEN ustep=89:vstep=59:wstep=29:write 0,rot:flag2=%1
    ' RWD rotation
    IF rot=%0 THEN
       IF flag2=%0 THEN ustep=29:vstep=59:wstep=89:write 0,rot:flag2=%1
    ' - button
    IF PORTE.0=%1 then
       if flag8=%0 then
          IF menu=%0 THEN mpos=mpos-1:d=1200:E=%0:F=%0
       flag8=%1
    ' + button
    IF PORTE.1=%1 then
       if flag9=%0 then
          IF menu=%0 THEN mpos=mpos+1:d=1200:E=%0:F=%0
       flag9=%1
    ' Run/stop button
    IF PORTC.0=%1 THEN
       IF run=%0 AND mpos<6 AND flag3=%0 THEN run=%1:flag1=%0:flag3=%1:f=%0
       IF run=%1 AND flag3=%0 THEN run=%0:flag1=%0:flag3=%1:f=%0
    ' FWD/RWD button
    IF PORTC.1=%1 THEN
       IF rot=%0 AND run=%0 AND flag4=%0 THEN rot=%1:flag2=%0:flag4=%1
       IF rot=%1 AND run=%0 AND flag4=%0 THEN rot=%0:flag2=%0:flag4=%1
    ' Menu/OK button
    IF PORTC.2=%1 THEN
       IF menu=%0 AND run=%0 AND mpos>5 AND flag5=%0 THEN menu=%1:flag5=%1
       IF menu=%1 AND flag5=%0 THEN menu=%0:flag5=%1
    ' Buttons released state
    IF PORTC.0=%0 THEN flag3=%0
    IF PORTC.1=%0 THEN flag4=%0
    IF PORTC.2=%0 THEN flag5=%0
    IF PORTE.0=%0 THEN flag8=%0
    IF PORTE.1=%0 THEN flag9=%0
    ' LCD first line writing
    c=c+1
    if c>800 then
       IF rot=%1 THEN LCDOUT $fe,$2,"+"
       IF rot=%0 THEN LCDOUT $fe,$2,"-"
       LCDOUT DEC freq DIG 3,DEC freq DIG 2,DEC freq DIG 1,".",DEC freq DIG 0,"Hz"
       IF run=%1 THEN LCDOUT REP 32\5,"RUN"
       IF run=%0 THEN LCDOUT REP 32\4,"STOP"
       c=0
    ' Inverter menu (LCD second line writing)
    SELECT CASE mpos
    ' Menu limits
    IF mpos<1 THEN mpos=1
    IF mpos>11 THEN mpos=11
    IF run=%1 THEN
       IF mpos>5 THEN mpos=5
    ' Current sensing submenu
    CASE 1
    d=d+1
    if d>1200 then
       idisp=isense**40000
       lcdout $fe,$c0,$1,$20,"1 ISENS: ",DEC idisp DIG 2,DEC idisp DIG 1,".",DEC idisp DIG 0,"A"
       d=0
    ' Voltage sensing submenu
    CASE 2
    d=d+1
    if d>1200 then
       udisp=usense**29600
       lcdout $fe,$c0,$1,$0,"2 USENS: ",DEC3 udisp,"V",32
       d=0
    ' Temperature sensing submenu
    CASE 3
    d=d+1
    if d>1200 then
         tdisp=(tsense-280)/8
         lcdout $fe,$c0,$1,$0,"3 TEMP: ",DEC tdisp DIG 1,DEC tdisp DIG 0,$df,"C",REP $20\2
         d=0
    ' Last fault reading submenu
    CASE 4
    if e=%0 then
       lcdout $fe,$c0,$1,$0,"4 LASTFAULT: ",DEC1 lastf
       e=%1
    ' Firmware version reading submenu
    CASE 5
    IF f=%0 then
          lcdout $fe,$c0,$1,$20,"5 FW: V2011.00"
          f=%1
    END SELECT
    GOTO lp
    ' PWM update interrupt (timer 1)
    pwmint:
    ' Timer management
    T1CON.0=%0
    copy.HIGHBYTE=TMR1H
    copy.LOWBYTE=TMR1L
    copy=copy+rld
    TMR1H=copy.HIGHBYTE
    TMR1L=copy.LOWBYTE
    T1CON.0=%1
    ' PWM U phase calculation
    uduty=sine[ustep]
    uduty=(uduty<<res)**amp
    ' PWM V phase calculation
    vduty=sine[vstep]
    vduty=(vduty<<res)**amp
    ' PWM W phase calculation
    wduty=sine[wstep]
    wduty=(wduty<<res)**amp
    ' PWM U, V and W update
    PDC0H=uduty.HIGHBYTE
    PDC0L=uduty.LOWBYTE
    PDC1H=vduty.HIGHBYTE
    PDC1L=vduty.LOWBYTE
    PDC2H=wduty.HIGHBYTE
    PDC2L=wduty.LOWBYTE
    ' Phase angle calculation
    @ decf _ustep,1
    @ decf _vstep,1
    @ decf _wstep,1
    ' Phase angle reinitialization
    IF ustep=0 THEN ustep=89
    IF vstep=0 THEN vstep=89
    IF wstep=0 THEN wstep=89
    @ INT_RETURN
    ' PWM carrier frequency configuration subroutine
    pwmsub:
    IF pwmf=1 THEN PTPERH=$f:PTPERL=$ff:res=6
    IF pwmf=2 THEN PTPERH=$7:PTPERL=$ff:res=5
    IF pwmf=3 THEN PTPERH=$3:PTPERL=$ff:res=4
    IF pwmf=4 THEN PTPERH=$1:PTPERL=$ff:res=3
    ' LCD backlight subroutine
    blsub:
    if BL=%1 then
        HIGH PORTD.4
        low PORTD.4
    ' Over current interrupt
    ocint:
    flt=4
    GOTO fltsub
    @ INT_RETURN
    ' Emergency stop interrupt
    stopint:
    flt=5
    GOTO fltsub
    @ INT_RETURN
    ' Inverter fault subroutine
    fltsub:
    ' Emergency stop of the inverter
    PWMCON0=%0
    T1CON.0=%0
    LOW PORTD.5
    LOW PORTD.6
    LOW PORTD.7
    ' Disable interrupts
    @ INT_DISABLE TMR1_INT
    @ INT_DISABLE INT0_INT
    @ INT_DISABLE INT2_INT
    ' Fault information
    lcdout $fe,$1
    lcdout $fe,$2,"FAULT!",REP $20\10
    lcdout $fe,$c0,"CODE: ",DEC flt,REP $20\9
    Hserout ["Fault|Code:",DEC1 flt]
    write 8,flt
    ' Fault LED ON
    HIGH PORTE.2
    This program control a 3-phase AC motor inverter. On my control board I got a HD44780 LCD and buttons, so I can navigate between menus when my motor is running or not. With that I can monitor DC bus current, DC bus voltage, IGBT module temperature, etc. Very useful. All of these things are working right.
    But sometimes when I navigate into this menu (when the AC motor is either on or off), and very randomly, the LCD is "freezing" and after 2 seconds the display is reseted. The 3-phase PWM outputs are not affected at all.
    Now, if I remove only the interrupts (TMR1_INT, INT0, INT2) of my program, this problem doesn't occur.
    So what's the problem?
    Default Re: LCD freezing problem with interrupts
    EDIT
    Corrected program part:
    ' Menu limits
    Still doesn't works.
    Exclamation Re: LCD freezing problem with interrupts
    Nothing? I've also tried to remove serial commands and CGRAM custom-made characters, same problem.
    Bombay, India
    Do you get the fault indication? I suspect, you are getting into the FltSub when you say the LCD is frozen.
    You can possibly disable the ocint and the stopint for checking this possibility. Does the LCD still freeze?
    Jan 2006
    Istanbul
    OSC is defined as 40Mhz, where is the config settings?
    which pic is this?
    Completely unrelated to your problem, or perhaps not but anyway.....
    Does these constructs really work? Do they even compile:
    ' FWD/RWD button
    IF PORTC.1=%1 THEN
    I think you need an ENDIF for each of those IF statements.
    Actually I'm not at home so I will try to remove ocint and stopint next friday.
    And no, I'm not getting into Fltsub when my LCD is frozen: in reality, the menu is reseted to the very first position (1: ISENS).
    ' FWD/RWD button
    IF PORTC.1=%1 THEN
    I've no problems with that (but I've modified this part to something like that):
    if rot=%0 then
    if run=%0 then
    if flag4=%0 then
    rot=%1
    flag2=%0
    flag4=%1
    Yeah, not very readable but take less program space than AND operator. And it works good.
    Quote Originally Posted by sayzer View Post
    which pic is this?
    A special PIC for motor control, it's the PIC18F4431, 10MHz quartz with PLL enabled (so 4*10=40MHz).
    Jan 2006
    Istanbul
    So, while LCDOUT command is being executed, an interrupt is occuring.
    To "test" this, you can disable all interrupts before lcdout command and enable them right after.
    This is just to see.
    But this will definitely effect your motor. It can give you a point anyway.
