12f675 to 16f877
Results 1 to 9 of 9
    Nov 2011
    Default 12f675 to 16f877
    Hello! I´m trying to send data from PIC12F675 to 16F877 via serout2.
    The 12F675 is generating the sequence:
    0,1,2,3,4,...,255
    And the 16F877 is receiving:
    128,129,130,131, ... , 157,158,159,128, 129,130,... Why?
    12F675 code:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    OPTION_REG.7 = 1 ' Disable pullups
    TRISIO = 101001
    CMCON = 7 ' Comparators OFF
    ANSEL = 0 ' A/D OFF -- Port pins all digital
    AL var byte
    TEMP var gpio.0 ' 1
    RELE1 var gpio.1 ' 0
    RELE2 var gpio.2 ' 0
    RES var gpio.3 ' 1
    TX var gpio.4 ' 0
    RX var gpio.5 ' 1
    al =0
    low RELE1
    low RELE2
    low tx
    serout2 TX,813,[AL]
    AL=AL+1
    16F877 code:
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    Define OSC 4
    ADCON1 = 7
    led var PORTC.0
    trim var PORTA.1
    rx var PORTB.5
    B0 var byte
    serIN2 RX,813,[B0]
    LCDOUT $fe, 1,"b0 ", dec B0
    LCDOUT $fe,$c0, bin (B0)
    GoTo Main
    Bit 7 is always set to 1, Why?
    Nov 2011
    Default Re: 12f675 to 16f877
    Any suggestion, please!
    May 2008
    Italy
    Remove PAUSE 100 on the receiver side.
    Cheers
    Al.
    Nov 2011
    I removed the Pause 100, but no change.
    May 2008
    Italy
    Did you set PORTB.5 as an input? (TRISB.5 = 1 in your 16f877)
    Your LCD DEFINES seems not corrected. Check them with the example given in page 95 of PBP manual.
    Al.
    On the 12F675, add this line ...
    DEFINE OSCCAL_1K 1
    And, remove the LOW TX before the SEROUT2 statement.
    Nov 2011
    Thank you for your comment. Its better, but still not work properly. This is my new code....
    '12F675 - TX
    OPTION_REG.7 = 1
    TRISIO = %00101001
    CMCON = 7
    ANSEL = 0
    AL var byte
    TX var gpio.4
    AL =0
    FOR ALl=0 to 200
    SERUOT2 TX,84,[AL]
    PAUSE 100
    NEXT AL
    GOTO main
    '16F877 - RX
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    Define OSC 4
    TRISB= %11111111
    ADCON1 = 7
    OPTION_REG.7 = 1
    RX var PORTB.5
    B0 var byte
    SERIN2 RX,84,[B0]
    LCDOUT $fe, 1,"DEC= ", dec B0
    LCDOUT $fe,$c0,"BIN= ", bin (b0)
    GOTO Main
    Now, on display i have...
    1,2,3,4,133,6,7,8..... or
    1,2,3,132,133,6,7...or
    129,2,3,132,5,6...etc.
    With "DEFINE OSCCAL_1K 1" in TX i have...
    193,192,193,194,195,194,195,196....
    I am beginner, but this is simple code! I don't understand!
    Sorry for my bad English.
    Check the spelling in the code
    SERUOT2 TX,84,[AL]
    Then..
    Add a dummy character to the TX
    Synch    CON "~"
    SEROUT2 TX,84,[Synch,AL]
    For the RX
    Synch    CON "~"
    SERIN2 RX,84,[WAIT(Synch),B0]
    Nov 2011
    Problem solved! Thank You All...
    Now code works fine:
    '--------- TX
    OPTION_REG.7 = 1
    TRISIO = 101001
    CMCON = 7
    ANSEL = 0
    AL var byte
    TX var gpio.4
    al =0
    for al=0 to 200
    SEROUT2 TX,813,["t","m","p",AL]
    next al
    '--------- RX
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 2
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    Define OSC 4
    TRISB= 111111
    ADCON1 = 7
    OPTION_REG.7 = 1
    RX var PORTB.5
    B0 var byte
    low rx
    serIN2 RX,813,[WAIT("tmp"),B0]
    Lcdout $fe, 1,"DEC= ", dec B0
    GoTo Main
    Best regards
