I have found a problem in the pic basic pro program used to compute relative humidity and dew point . Those program are available in this forum.
I will like now to post the corrected program that allows correct computation of RH_tc and dew point even if the temperature is below 0 deg C.
I hope it could help someone!
Ambrogio
quote:
for S_RH=100 TO 3500 STEP 50 ' change them as needed to generate an output list
for s_t=1000 to 8000 step 500 ' change them as needed to generate an output list
if S_T => 4000 then
TEMP=S_T-4000 ' TEMP *100
SIGNtc="+" ' POSITIVE
TEMP=4000-S_T ' TEMP *100
SIGNtc="-" ' NEGATIVE
DEBUG "S_T=",DEC S_T," T=",SIGNtc,DEC TEMP/100,".",DEC1 TEMP/10
COMPUTE_RH_T:
WY=405*S_RH
WY=DIV32 100
WX=S_RH*S_RH
WX=DIV32 1000
WX=WX*28
WX=DIV32 100
RHLIN=WY-WX-400 ' RH_LINEAR
WY=(8*S_RH+1000)/10
IF SIGNTC="+" THEN
IF TEMP> 2500 THEN
WX=(TEMP-2500)*WY
WX=DIV32 100
RHTC=RHLIN+WX/100
WX=(2500-TEMP)*WY
WX=DIV32 100
RHTC=RHLIN-WX/100
WX=(2500+TEMP)*WY
WX=DIV32 10000
RHTC=RHLIN-WX
DEBUG " S_RH=",DEC S_RH," RHlin=",DEC RHLIN/100,".",DEC1 RHLIN/10," RHtc=",_
DEC RHTC/100,".",DEC1 RHTC/10,"%"
COMPUTE_DP: ' COMPUTE DEW POINT....................................
'** Dewpoint Calculation
' See: SENSIRION Application Note "Dewpoint Calculation"
' logEW = (0.66077+7.5*T/(237.3+T)+(log(RH)-2)
' DP = ((0.66077-logEW)*237.3)/(logEW-8.16077)
TempDP=Temp/10
logEW=6608
'sign=TempDP.bit15
if s_t<4000 then ' we are below zero °C
sign=1
sign=0 ' we are above zero °C
wz=ABS TempDP
wx=(7*wz)+(wz/2)
'debug "Wx=",dec wx,13,10
if sign=0 then
wy=2373+wz
wy=2373-wz
wj=wx/wy
For ix=15 to 0 step -1
wx=(wx//wy)<<1
wz.bit0(ix)=wx/wy
next ix
wx=(-sign^((wj*10000)+(wz**10000)))+sign
logEW=wx+logEW
wx=RHtc/10
wj=(NCD wx) - 1
wx=wx<<(15-wj)
wz=0
For ix=14 to 0 step -1
wy=wx**wx
wz.bit0(ix)=wy.bit15
bt=~wy.bit15
wx=wy<< bt+(bt & wx.bit15)
next ix
wx=((wj*4000)**49321)+(wz**6021)
logEW=wx+logEW-30000
sign=logEW.bit15
logEW=(-sign^(((ABS logEW)+2)/4))+sign
wx=1652-logEW
sign=~wx.bit15
wx=ABS wx
wy=20402-logEW
wj=wx/wy
wx=(wx//wy)<<1
wz.bit0(ix)=wx/wy
Next
DP=((23730**wz)+5)/10
DP=(-sign^DP)+sign
'debug "DP=",DEC2 ABS DP/10,".",DEC1 ABS dp,13,10
'debug "dpC=",rep "-"\sign,dec abs DP/10,".",dec1 abs DP,13,10
'lcdout ins,line3,"dp=" ,DEC2 ABS DP/10,".",DEC1 ABS dp
'lcdout ins,line4,"dp=" ,rep "-"\sign,DEC ABS DP/10,".",DEC1 ABS dp
DEBUG " dp=", rep "-"\sign,DE
next s_t
next s_rh
unquote.
