PIC12F675 Timer1 Pause
Results 1 to 3 of 3
Threaded View
    Apr 2008
    Default PIC12F675 Timer1 Pause
    Hello
    I want to measure a voltage from a sensor 0.5V to 4.5V
    and convert it to a specific pulse..
    12uS 12uS 12uS
    zero = 0.5V = ||____________________||_____________________||
    180uS 180uS
    12uS 12uS 12uS
    fullScale = 4.5V= ||_______________________________||_______________ _________________||
    342uS 342uS
    I want to use a pic12f675 at 20MHZ use the adc to read the voltage , and output repeatteadly a 12uS pulse to GPIO.2
    Time between pulses is is 180uS for zero (adc read 0.5V) and 342uS fulscale (adc read 4.5V)
    I have done it with the following code using a small delay routine in assembler.
    @ DEVICE PIC12F675, HS_OSC, MCLR_OFF, PROTECT_ON, WDT_OFF,BOD_OFF
    DEFINE OSC 20           'cristal 20 Mhz 2x 22pf
    ADCON0 = 131 '000011 Set AN0 ON pino GPIO.0
    ANSEL = 101000 'set Fosc/64 'Cristal 20Mhz OBRIGA
    CMCON = 7 ' Comparators OFF
    TRISIO = �0001 ' GPIO.0 = Input outros output
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_SAMPLEUS 30 ' Set sampling time in uS
    '*** Definir Pinos e Variaveis
    PULSO var GPIO.2
    GPIO = 0
    adval Var Word ' adval to store analog reading 0 to 1023 (102 to 920)
    Sensor var word ' adval minus offset (0 to 818)
    n var word
    Tempo var word
    Zero var word   'store (180us delay) minus instruccion time of adc lines
    pulso = 1
    Pause 100 ' da tempo para tudo acordar
    Zero = 16 ' 16uS added to the lines below equal 180us
    Ciclo:
    Pulso =0 'Inicio impulso negativo 12 uS
    pauseus 16
    PULSO = 1  'Fim impulso negativo 12 uS
        ADCIN 0, adval ' Read channel AN0 to adval
          If adval > 102 then
          Sensor =adval -102   'ofset 1024/10 = 102,4 +/- 0,5V sensor zero
            sensor =1     ' overflow dá valores perto de 65000
         ' Adval voltage 0,5 V 180 uS + Widht Sensor Zero
         ' Adval Voltage 4,5 V 340 uS + Widht Sensor Full scale
    pauseus zero ' 180 uS including above instruction time
    sensor = (sensor /4) +1 ' the assembler delay overflows if sensor = 0
    'sensor = 84  ' for testing
    Delay:    ' Adds the sensor reading to fixed 180uS delay
    @ nop
    @ decfsz _Sensor,F
    @ goto _Delay
    Goto Ciclo ' Do it forever
    Problem is that i have small resolution
    the assembler delay is only 8bits (256 steps
    adval variable ranges 102 to 920
    sensor variable ranges 0 to 818
    sensor /4 ranges 0 to 204
    actualy only 204 steps
    My assembler knowledge is very limited. actualy i learned a little bit only for this project.
    I searched the web tried to have a 16bit delay routine in assembler but could not do it.
    I would like to rewrite everything to read analog pin then use timer1 and interrupt
    i never used interrupts i searched the web and the forum for examples and tried some code
    without sucess.
    As a newbie this what i think i have to do
    Cristal 20Mhz / 4 = 5Mhz clock = 0.2uS step. As sensor ranges from 0 to 818 . 818 * 0.2uS = 163.6 uS
    very close to 162 uS variation i want
    After reading the datasheet these are the registers i think i must tweak.
    set bits 6 and 7 of INTCON register
    clear PIR1 bit 0 = TMR1IF
    Set T1CON = �000001 ' to turn on timer1
    i think timer 1 counts up and i want to delay 1 to 818 clock cicles
    so i must preset timer1 to 65535 - sensor or (0 to 818)
    so sensor = 65535 - sensor
    TMR1H = Sensor.Highbyte
    TMR1L = Sensor.Lowbyte
    i realy do not understand how interrupts acts here
    i think i must
    read the adc in a loop
    load TMRH1 and TMR1L with the 64717 to 65535 value
    turn on timer1 ' T1CON = �000001
    then on IsR stop timer1,pause 180uS , output the 12uS pulse on gpio.2, clear interrupt flag
    I think somthing like this
    Sensor = 0
    INTCON = 0
    PIR1 = 0
    PIE1 = �000001
    ON INTERRUPT GOTO Isr
    Ciclo:
        ADCIN 0, adval
          If adval > 102 then
            Sensor = adval -102
          Else
                Sensor =1
              Endif
             Sensor = 65535 - Sensor
             TMR1H = Sensor.HighByte
         TMR1L = Sensor.LowByte
         T1CON = �000001
        Goto Ciclo
    Isr:
    T1CON = 0
    pauseus 180
    GPIO.2 = 1
    pauseus 12
    GPIO.2 = 0
    PIR1 = 0
    RESUME
    ENABLE
    Can anyone point me the right direction ?
    Fernando Carvalho
