Timer based PWM with HPWM
Results 1 to 2 of 2
    Feb 2004
    Michigan, USA
    Default Timer based PWM with HPWM
    Having a little trouble setting up 2 PWM signals. I'm using the 18F2550 with 20MHz ceramic res, setup for USB. DEFINE OSC is 48MHz.
    Based on the pwm used in this design: http://www.picbasic.co.uk/forum/showthread.php?t=15602 I can get the 260Khz pwm to work fine but when I use CCP2 for the HPWM 2 output, HPWM 2 has a frequency that matches the timer based pwm on CCP1.
    If I setup a HPWM on CCP1 of any frequency, and another on CCP2 also of any frequency, they both change to 6.6KHz. However if I disable either one, then the remaining one functions at the desired frequency.
    Any ideas on what I am missing?
    Feb 2010
    USA, New England
    Default Re: Timer based PWM with HPWM
    Take a look at table 15-2 in the datasheet. If I understand it correctly both hardware PWMs must share the same frequency.
    Best Regards,
    Paul
