DT Int-14 seems not working!
Results 1 to 6 of 6
    May 2008
    Italy
    Default DT Int-14 seems not working!
    I have been using the Rx interrupt with pic 16F88 several times without any problem since today.
    The simple code below just go through ISR (Getbytes) only once after reset then no way to see the led_0 showup again, while Led_1 and Led_2 just work as they should.
    Anybody sees where the error could possibly be?
    INCLUDE "DT_INTS-14.bas"        ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"        ; Include if using PBP interrupts
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
      ANSEL = 0
      CMCON = 7
      TrisA = 0
      TrisB = %00000100
      PortA = 0
    DEFINE OSC 16
    'DEFINE HSER_TXSTA 20h ' Enable transmit, BRGH = 0
    DEFINE HSER_SPBRG 51  ' 4800 Baud @ 16MHz, 0,17%
    Led_0                   var PortB.0
    Led_1                   var PortB.3
    Led_2                   var PortB.4
    A0                      var word
    New_L                   var byte
            INT_Handler     RX_INT,    _Getbytes,   PBP, yes
        INT_CREATE              ; Creates the interrupt processor
        INT_ENABLE RX_INT    ; enable RX_INT interrupts
    Led_0 = 1
    For A0 = 0 to 10
    Led_2 = !Led_2
    Led_1 = !Led_1
    next A0
    PortB = 0
    goto MainLoop
    Getbytes:
    Led_0 = !Led_0
    @ Return
    MainLoop:
    Hserin 1,TOut,[New_L]
    if New_L > 0 then Led_1 = !Led_1
    TOut:
    A0=A0+1
    if A0 = 1000 then
    Led_2 = !Led_2
    A0 = 0
    goto MainLoop
    Thank for the help.
    Al.
    Default Re: DT Int-14 seems not working!
    Not sure if it is the problem but
    is after the ASM block
    @ INT_ENABLE RX_INT    ; enable RX_INT interrupts
    At least that is how the example is done.
    http://darreltaylor.com/DT_INTS-14/elapsed.html
    May 2008
    Italy
    Thank you Dave, but it didn't work also with the INT_ ENABLE outside the asm/ endasm block.
    Cheers
    Al.
    You do not return from your int routine. Use @ INT_RETURN
    May 2008
    Italy
    Thanks Ioannis, you spotted the problem! Now it works.
    Cheers
    Al.
    Glad you got it working. You are welcome.
