As far as I can see you've already done it.
You have your pot, which you read with ADCIN and get a value in rdpot, then you have your sensor which read with count and get a value in pulse. Then just doOr you can use a series of IF-THEN to light up the various LEDs or perhaps SELECT CASE, likeCode:Flow: COUNT GPIO.1, 500, pulse ADCIN 1, rdpot IF pulse < rdpot THEN ' Compare pulse with rdpot ' Flow is under limit ' Do what needs to be done. ELSE ' Flow is OK ENDIF Goto FlowSomething like that (untested). To be honest, when I think about it I'm not exactly sure how SELECT CASE works in this case. I mean when pulse < rdpot all cases are true and I'm not sure if it only executes the first the one and then exits (which is what we want) or if it continues to evauluate the other cases as well. Worth a try peraps.Code:' rdpot sets the absolute low limit = red ligtht and stop SELECT CASE pulse pulse is < rdpot ' Stop and turn on red LED pulse is < (rdpot * 2) ' Turn on yellow LED pulse is < (rdpot * 4) 'Turn on Green LED END SELECT
