LCD Troubles on 16F685
Results 1 to 10 of 10
Threaded View
  1. #8
    Default Re: LCD Troubles on 16F685
    OK, next step is to initialize the ADC. Tried it but cannot go further. Would be nice to see a run-down of all the settings like ADSEL, for novice programmers like me to see exactly what these settings do. So here is the code that does not read ADC port AN0. Now, I use PortA.4 and PortA.5 so I use this:
    TrisA = 001111
     __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    high portc.0
    DEFINE ADC_BITS 10       ' 10 bit A/D Conversion
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50   ' 50 uS A/D sample time
    VRCON  = 000000       ' Disable Comparator Voltage Reference
    ANSEL  = 000001       ' Set pin (AN0) to analog input, the rest to digital
    ADCON0 = 001001       ' Set up A/D converter - Right Just., VDD REF., CH 0, ON
    ADCON1 = 110000       ' Set up A/D Converter clock source to internal RC
    TrisA = 001111
    define LCD_DREG PORTB                      ' Data on PORTB
    define LCD_DBIT 4                          ' Data starts on PORTB.4
    DEFINE LCD_RSREG PORTA                     ' RS on PORTA
    DEFINE LCD_RSBIT 4                         ' RS on A4
    DEFINE LCD_EREG PORTA                      ' E on PORTA
    DEFINE LCD_EBIT 5                          ' E on A5
    DEFINE LCD_BITS 4                          ' LCD 4 bit mode
    DEFINE LCD_LINES 2                         ' 2 line LCD display
    Define LCD_COMMANDUS 2000                  ' Command Delay (uS)
    Define LCD_DATAUS 50                       ' Data Delay (uS)
    adval var byte
    Pause 500       ' Wait for LCD to startup
    mainloop:
     ADCIN 0, adval
        LCDOut $fe, 1 ' Clear LCD screen
     LCDOut "Magnetic Pulser"
     'Charac 1234567890123456
        LCDOut $fe, $c0 'Jump to second line
        lcdout "Voltage:",  DEC adval
        toggle portc.0
     GoTo mainloop
