My DT_Interrupts broke in PBP3... guess I'm too dense too figure out why
Results 1 to 7 of 7
    California, USA
    Default My DT_Interrupts broke in PBP3... guess I'm too dense too figure out why
    Well, now that I've switched from PBP2..6 to PBP3 I seem to be having trouble with DT_Interrupts in some "previously working" code.
    I've read the manual about migrating from PBP2.6 to 3.0, and have successfully applied it to other programs, but can't seem to get it going on this one.
    The chip is a 16F726. It uses DT_interrupts in a touch sensor routine.
    The code worked when compiled with PBP2.6 but creates some "ASM Errors" with PBP3
    Here's the errors I get:
    Here's my ASM code. First, some config stuff.
    Used to be:
    @  __config _CONFIG1, _DEBUG_OFF & _PLL_EN & _BORV_2_5 & _BOR_ON & _CP_OFF & _MCLRE_OFF & _PWRT_EN & _WDT_OFF & _INTOSCIO
    @  __config _CONFIG2, _VCAP_RA0
    Now looks like:
    #endCONFIG
    Then I set up the interrupt. Here's my OLD code for PBP2.6:
    '-----Set up Interrrupts
            INT_Handler   TMR1GATE_INT,  _CheckCount,   PBP,  yes
    @ INT_ENABLE  TMR1GATE_INT     ; enable Timer 2 interrupts
    And the NEW code for PBP3:
    INT_ENABLE  TMR1GATE_INT     ; enable Timer 1 interrupts
    At the end of my interrupt handler routine I had this:
    @ INT_RETURN
    Which has been changed to this:
    INT_RETURN
    That'all the ASM there is.
    I clearly haven't done it right... could someone point me in the right direction?
    Thanks!
    Default Re: My DT_Interrupts broke in PBP3... guess I'm too dense too figure out why
    DT_INTS in not part of the device configuration.
    Don't put #CONFIG/#ENDCONFIG around them. Put it back to ASM/ENDASM.
    And watch the indentation. ASM is sensitive to that.
    California, USA
    Thanks Darrel!
    I knew I'd done something stupid and that was it!
    Welll... part of it.
    It did indeed get rid of those errors, but it brought up some fresh ones.
    I'm clearly still not getting it right. (I seem to have lost the "embarrassed" smilie, but consider it Inserted Here.)
    Here's the code again:
    @ INT_ENABLE  TMR1GE     ; enable Timer 2 interrupts
    Thanks much
    @ INT_ENABLE TMR1GATE_INT ; enable Timer 1 gate interrupts
    California, USA
    I'm sorry Darrel, I'm getting to where I can't even cut & paste the right code anymore.
    I think I need to step away from the keyboard and go make some cookies or something instead.
    THIS gives the errors shown in my last post.
        INT_CREATE               ; Creates the interrupt process
    @ INT_ENABLE  TMR1GATE_INT     ; enable Timer 1 interrupts
    Sorry, since you said the 2.60 code worked, I just copied from that post.
    But actually, it's ... T1GATE_INT
    California, USA
    Hi Darrel,
    Thanks for your help. I'm sorry I haven't followed through with this yet.
    I discovered wet carpet in a spare bedroom and traced it back to a leak in the bathroom.
    Rotten floor, ruined carpet, damaged wall, the whole works.
    Major repairs underway and I don't know when I'll have time for PIC games again...
    But I *really* appreciate all your help and I hope you and your family are having the best thanksgiving ever this year!
