Need help on pic connect 4
Results 1 to 2 of 2
    Feb 2011
    Default Need help on pic connect 4
    Im doing a pic based connect 4 using a led matrix for my senior project in high school. I am very novice at coding so please make sure to keep that in mind while critiquing my work. All i want it to do for now is to have a light at the top left to be on and when you push a button it falls down and stops at the bottom,then when you press a button again another one falls on top of that and so on. I have the first led falling but after the led stops it starts stacking until the whole left column is on. I don't know how this is possible when i have
    if (b.0[rows]=0)then fall=0 : goto main
    it acts if it keeps going through the loop main. Any suggestions?
    fall var byte
    Shift var byte
    pb1 var porta.0
    pb2 var porta.1
    rowvar var byte
    b var byte
    rows var byte
    stack var byte
    row1 var byte
    row2 var byte
    row3 var byte
    row4 var byte
    row5 var byte
    row6 var byte
    row7 var byte
    ansel=0
    anselh=0
    fall = 0
    Shift = 7
    down=1
    portb=b
    rows=0
    stack=0
    trisA=111111
    trisb=000000
    trisc=000000
    trisd=000000
    b=~000000
    portc=000001
    portd=000000
       loopa:
          portb=b+b1
           portb=b
        if (pb1==0 & b.7==0) then fall=1
          if (fall==1) then
            b.0[Shift] = 1
            b.0[Shift - 1] = 0
            Shift = Shift - 1
        goto loopa
         portb=b
          rows=rows+1
                if rows=6 then rows=0
           if stack=6 then stack=5
         if stack = 0 then b=~000010
         if stack = 1 then b=~000110
         if stack = 2 then b=~001110
         if stack = 3 then b=~011110
         if stack = 4 then b=~111110
         if stack = 5 then b=~111110
         portc=000001
         stack=stack+1
    goto loopa
    Oct 2009
    Utah, USA
    Default Re: Need help on pic connect 4
    This line in your code ...
    is the same as...
    you probably need this...
      fall=0
    That way the "goto main" will only be executed if the preceding IF statement is true
    from the PBP manual...
    4.13. Multi-statement Lines
    In order to allow more compact programs and logical grouping of related commands, PBP supports the use of the colon
    ":" to separate statements placed on the same line. Thus, the following two examples are equivalent:
    W2 = W0
    W0 = W1
    W1 = W2
    is the same as:
    W2 = W0 : W0 = W1 : W1 = W2
    This does not, however, change the size of the generated code.
    Dwight
