12F510 CALL subroutine problem ...
Results 1 to 3 of 3
Threaded View
    Feb 2010
    Default 12F510 CALL subroutine problem ...
    Hello to all,
    i am having a headache using CALL in 12F510...see that...
    The PIC gets a continuous CLK in pins GPIO.3 and .4
    (This is only a testing part of the full program , in order to understand what caused the full program to WDT endlessly)
    So...THIS TEST CODE IS NOT WORKING...it watchdogs endlessly....
    CODE/
    @ DEVICE pic12F510, INTRC_OSC
    @ DEVICE pic12F510, WDT_ON
    @ DEVICE pic12F510, MCLR_OFF
    @ DEVICE pic12F510, PROTECT_OFF
    IN_A VAR GPIO.4
    IN_B VAR GPIO.3
    OUT_A VAR GPIO.5
    OUT_B VAR GPIO.1
    LED VAR GPIO.5
    ADCON0.6 = 0 ' A/D OFF
    ADCON0.7 = 0 'A/D OFF
    CM1CON0.3 = 0 'COMPARATOR OFF
    OPTION_REG.5 = 0 ' TOCKI OFF
    TRISIO = 00011100
    MAIN_LOOP:
    CLEARWDT
    CALL WAIT_HI_IN_A
    OUT_A = 1
    OUT_B = 1
    pauseus 100
    OUT_A = 0
    OUT_B = 0
    GOTO MAIN_LOOP
    WAIT_HI_IN_A:
    CLEARWDT
    IF IN_A = 0 THEN GOTO WAIT_HI_IN_A
    /CODE
    But... if i move the WAIT_HI_IN_A routine inside the mainloop ... it works! .... no WDT timeout , and pulses going out of the GPIO outputs .... what is happening?
    CODE/
    IN_A VAR GPIO.4
    IN_B VAR GPIO.3
    OUT_A VAR GPIO.5
    OUT_B VAR GPIO.1
    LED VAR GPIO.5
    TRISIO = 00011100
    MAIN_LOOP:
    CLEARWDT
    WAIT_HI_IN_A:
    CLEARWDT
    OUT_A = 1
    OUT_B = 1
    pauseus 100
    OUT_A = 0
    OUT_B = 0
    GOTO MAIN_LOOP
    /CODE
    I also have a second problem with the above code...
    The original plan was ... "OUT_A VAR GPIO.0" , but GPIO.0 does really strange things...
    i get unstable triangle voltages , so for now i use GPIO.5 instead which works fine (but pcb's have already manufactured , due to hurry )...
