Communication between two PicChip
Results 1 to 29 of 29
    Sep 2005
    Campbell, CA
    Default Re: Communication between two PicChip
    Are you using HSERIN for the receive side?
    Just do this -
    LCDOUT $FE,$1
    Topp:
    HSERIN [X]
    LCDOUT X
    Goto Topp
    Charles Linquist
    Sep 2006
    this is what I have now. the tiny rail of the breadboard seems to be defective, although I tested it with my multimeter and it seems to be conducting, but then if I put the wire from the transmitting pic directly to the receiving chip leg then I could see something on the LCD. that fixed. I am sending 5 or 22 or 85 from the TX pic and I am always receiving 49 on the RX chip....
    Mainloop:
    Pause 50
    Hserin [encoded22]
    PAUSE 100
    lcdout $FE,1, "input ", bin encoded22
    pause 200
    goto Mainloop
    Sep 2006
    I removed the defines commands for HSERIN, ans used the serout command. It WORKS !!!. But i would like to make the HSEROUT AND HSERIN command works. I still get the number 48 or 49 showing up. sometimes after a minute or so the LCD shows some erratic behaviour, showing a lot oo???oo?? on both of the line.....
    any ideas?
    k
    Sep 2006
    i CHANGES BREADBOARD, USED BRAND NEW CHIPS, STILL i AM GETTING 49 IN THE RECEIVING PIC................ANY IDEAS ???? OUPS CAPS LOCK...
    Ken
