Communication between two PicChip
Results 1 to 29 of 29
    Sep 2006
    Default Re: Communication between two PicChip
    STILL NOT TRANSMITTING. as least I am getting any compilation errors..: here is my transmitter code:
    (I just see these before word on my LCD)
    INCLUDE "modedefs.bas"
     OSCCON = 110000 '8 Mhz
     Define OSC 8
        ' Set transmit register to transmitter enabled
        DEFINE HSER_TXSTA    20h
        ' Set baud rate
        DEFINE HSER_BAUD    2400
        ' Set SPBRG directly (normally set by HSER_BAUD)
        DEFINE HSER_SPBRG    25
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    '// LCD configuration //
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 0 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    cou var byte
    temp1 var byte
    temp2 var byte
    Mainloop:
      temp1 =18: temp2 =22
      cou =44
    lcdout $FE,1, "TempC: ", dec (temp1) , ".", dec2 temp2," ",$DF,"C"
    lcdout $FE,$C0, bin cou , ".","F"
    pause 400
    Hserout [DEC temp1]
    PAUSE 50
    lcdout $FE,1 : LCDOUT "second  ", dec (temp2 / 100) , ".", dec2 temp1," ",$DF,"r"
    lcdout $FE,$C0, dec cou , ".","23"
    pause 400
    goto mainloop
    and my receiver code
     Define OSC 8
         ' Set receive register to receiver enabled
        DEFINE HSER_RCSTA    90h
        ' Set baud rate
     encoded22 var word
    Mainloop:
    lcdout $FE,1 , "hello  "
    lcdout $FE,$C0, "before"
    pause 300
    Hserin [DEC encoded22]
    PAUSE 100
    lcdout $FE,1, "after"
    lcdout $FE,$C0, "AFTER: ", "-", dec encoded22 , "After"
    Pause 300
    goto Mainloop
    How are the two chips connected?
    chip#1 ground to chip#2 ground
    chip#1 TX to chip #2 RX
    Sep 2006
    YES THE CHIPs has a common ground. RB5 is going to the receiving pic on RB2 (PIC16F88)
    ken
    Try these settings on both the Tx and RX chip
    DEFINE HSER_SPBRG 51  ' 2400 Baud @ 8MHz, 0.17%
    Sep 2006
    just copied and paste your code and still did not work. Same as before.....
    ken
    Sep 2005
    Campbell, CA
    Do you have your TX pin set for output (TRIS = 0)?
    Charles Linquist
    Sep 2006
    i ADDed this after I sent the code yesterday.:
    TRISB = %00000000
    AND
    the other pic:
    TRISB =%11111111
    could it be in the include file?
    K
