Communication between two PicChip
Results 1 to 29 of 29
    Sep 2005
    Campbell, CA
    Default Re: Communication between two PicChip
    There are so many answers to that question. "Best" is a big word.
    While there are lots of options, just quit fighting and use HSEROUT/HSERIN. Easy to use, and has full PBP and DT-INT support. It is a waste of my time to try to convince you of anything. If you choose to use that method I propose, I will give you some pointers, if you don't, you will have to look for help from others.
    Charles Linquist
    Sep 2006
    I was heading in that direction using HSEROUT, starting reading the pic datasheet communication section and that led me to ask that question. I'll be working on HSEROUT tonight. I think it is a better practice then using serout in a free style way.
    Sep 2006
    working on it
    Sep 2006
    STILL NOT TRANSMITTING. as least I am getting any compilation errors..: here is my transmitter code:
    (I just see these before word on my LCD)
    INCLUDE "modedefs.bas"
     OSCCON = 110000 '8 Mhz
     Define OSC 8
        ' Set transmit register to transmitter enabled
        DEFINE HSER_TXSTA    20h
        ' Set baud rate
        DEFINE HSER_BAUD    2400
        ' Set SPBRG directly (normally set by HSER_BAUD)
        DEFINE HSER_SPBRG    25
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    '// LCD configuration //
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 0 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    cou var byte
    temp1 var byte
    temp2 var byte
    Mainloop:
      temp1 =18: temp2 =22
      cou =44
    lcdout $FE,1, "TempC: ", dec (temp1) , ".", dec2 temp2," ",$DF,"C"
    lcdout $FE,$C0, bin cou , ".","F"
    pause 400
    Hserout [DEC temp1]
    PAUSE 50
    lcdout $FE,1 : LCDOUT "second  ", dec (temp2 / 100) , ".", dec2 temp1," ",$DF,"r"
    lcdout $FE,$C0, dec cou , ".","23"
    pause 400
    goto mainloop
    and my receiver code
     Define OSC 8
         ' Set receive register to receiver enabled
        DEFINE HSER_RCSTA    90h
        ' Set baud rate
     encoded22 var word
    Mainloop:
    lcdout $FE,1 , "hello  "
    lcdout $FE,$C0, "before"
    pause 300
    Hserin [DEC encoded22]
    PAUSE 100
    lcdout $FE,1, "after"
    lcdout $FE,$C0, "AFTER: ", "-", dec encoded22 , "After"
    Pause 300
    goto Mainloop
    How are the two chips connected?
    chip#1 ground to chip#2 ground
    chip#1 TX to chip #2 RX
    Sep 2006
    YES THE CHIPs has a common ground. RB5 is going to the receiving pic on RB2 (PIC16F88)
    ken
    Try these settings on both the Tx and RX chip
    DEFINE HSER_SPBRG 51  ' 2400 Baud @ 8MHz, 0.17%
