PICAXE servo command
Results 1 to 4 of 4
    Question PICAXE servo command
    Hello,
    I do a lot of work with servo's and I am coming up against a wall with synchronizing them. I usually do the following:
    portb.0 = 1
    pauseus (servo1 * 4) + 960 ; scaling factor to give me 2.0ms full scale.
    portb.0 = 0
    If I repeat the above 4 or more times I am going to see the signals staggered in time. 1ms at the least and 2ms at the most between each routine. The picaxe seems to be able to start all servo's at once and update on the fly each servo (8 servos). Has anyone tried to do this?
    I am thinking about using a 20ms interrupt to seed ADC values, synchronously start low to high output on 8 pins and decrement variables in main. Like the following:
    intMe: ; interrupt every 20ms
    asm
    portb = 1
    load ADC0 into counter 1
    load ADC1 into counter 2
    etc
    etc
    return from interrupt
    end asm
    if servo1 > 0 then
    servo1 = servo1 - 1
    portb.0 = 0
    if servo2 > 0 then
    servo2 = servo2 - 1
    portb.1 = 0
    etc
    servo3 ~ servo8
    pauseus 100
    Is there a better way of doing the above mentioned? I can't shake the feeling that it seems too brute force and there should be a more elegant way of doing this.
    Nick
    Sep 2005
    Campbell, CA
    Default Re: PICAXE servo command
    I'm certainly no expert with servos, but can't Darrel's SSPWM do this?
    Charles Linquist
    The common trick is to use a free running timer and the " interrupt on match " feature of a CCP module ...
    you "launch" all the servos signals together and reset relative output when CCP detects their duration reached ...
    Much Better done in assembly than Basic , for the interrupt stubb ...
    BTW : Picaxe ??? Does that thing really exist ???
    May 2007
    Not only do they exist but doing well with worldwide distribution http://www.picaxe.com/Distributors
