Digital Hourmeter
Results 1 to 15 of 15
    No, it's my fault... not reading the thread properly from the beginning...
    What I told you was valid for the timer keeping it's own time...
    But, nevertheless if you want the Timer to count 21600 (or however many) pulses from an external source then yes, it's 65536-21600=43936, or $ABA0 that needs to be preset into TMR1H & TMR1L. Note I'm subtracting from 65536 ($0000 or zero) and not from 65535 ($FFFF), because the interrupt is on the roll from 65535 ($FFFF) to 65536 ($0000).
    Look at the T1CON Register for your PIC... you will also have to set TMR1CS for EXTERNAL input and provide your 60Hz pulses on the appropriate T1CKI pin for your PIC.
    Feb 2004
    Michigan, USA
    So I am on track with this?
    Timer counts up, sets the interupt. Interupt causes CounterA to advance by 1, which increments the digits for the display. Obviously, the segment drive logic is not there yet.
    Tenths var word
    Units var word
    Tens var word
    Hundreds var word
    Thousands var word
    Tenthousands vAR WORD
    Gosub SetTimer ' Set the Timer
    On Interrupt goto CounterA
    PIE1.0=1 ' Enable TMR1 Interrupts
    SetTimer:
    T1CON.0=0 ' Stop the Clock
    TMR1H=$AB ' Set Timer Highbyte
    TMR1L=$A0 ' Set Timer Lowbyte
    T1CON.1=1 ' Restart the Clock
    PIR1.0=0 ' Reset TMR1's Interrupt Flag
    CounterA:
    ' Timer Interrupt Handler
    Gosub SetTimer ' Set the Timer for next count
    Tenths=Tenths+1 ' Increment 1/10TH minute Counter
    If Tenths>9 then
    Tenths=0
    Units=Units+1 ' Increment the Units
    If Units>9 then
    Units=0
    Tens=Tens+1 ' Increment the Tens
    If Tens>9 then
    Tens=0
    Hundreds=Hundreds+1 ' Increment the Hundreds
    If Hundreds>9 then
    Hundreds=0
    Thousands=Thousands+1 'Increment the Thousands
    If Thousands>9 then
    Thousands=0
    Tenthousands=Tenthousands+1 'Increment the Tenthousands
    Resume
    Ummm.... on track?.... well maybe you're on a siding but you've not reached the main line yet... theory might be there, but reality it won't run - way to go yet...
    Tenths var word
    Units var word
    Tens var word
    Hundreds var word
    Thousands var word
    Where's the PIC initialisation here? No Registers are configured, no I/O, TMR1 is not set up to accept external pulses...
    At this point your program runs into a subroutine without calling it. You should have a logical program loop.
    SetTimer:
    Your program encounters a Return with nowhere to return to... so at this point it dies - quite apart from the fact it's counting INTERNAL clock ticks.
    You've not set any ENABLE/DISABLE to identify which sections of your code will be interruptable, and which sections should be protected from interrupt.
    That's just a starter without going into any depth.
    Feb 2004
    Michigan, USA
    I realize all the initialization settings are not there! I was just asking if what I posted made any sence. I also realize that there is no program loop, becuase I havent created it. I'm just trying to learn this stuff piece by piece. It easier for me to break it down into sections to figure exactly what is going on before I attempt to write a huge program with a 1000 mistakes only to get disheartened and pay someone to do it for me.
    Dec 2003
    Wichita KS
    Hello Jm,
    Jm>>I was just asking if what I posted made any sence. I also realize that there is no program loop, becuase I havent created it. I'm just trying to learn this stuff piece by piece. It easier for me to break it down into sections to figure exactly what is going on before I attempt to write a huge program with a 1000 mistakes only to get disheartened and pay someone to do it for me.<<
    Naw, I think we can help you figure it out <smile>..
    I am curious... what are you going to use your hour meter for??? I am a pilot, and I am building a new airplane right now... I am going to use a PIC chip as a HOBBS meter for my Engine, as well as a RPM and a possibly a Altimeter/Velocity (if I can find a sensor that is cheap enough). Your project looks almost exactly like mine to many a degree, that is why I ask.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Feb 2004
    Michigan, USA
    Hi Dwayne,
    The project is for an air compressor system. Your project sounds more interesting though. Godd luck with that, and post up some pictures of your work in progress on the airplane.
    James.
    Dec 2003
    Wichita KS
    Hello James,
    They would kill me if I posted pics of a bird here..<g>. I would be more than happy to email pics. But when I get my project done on the PIC, I will post the code and schematic for everyone.
    Dwayne
    I am using a inductor type system to monitor the RPM. I have found that just 1 turn of wire around the spark wire is more than 50 volts!!
    So, what I did, was put a 5V zenor to the base of a PNP, and let the PNP be the trigger to my PIC. Using Pulsein, I count the time between off and on, and for 1000 hz, I get about 960 on my Pulsein calculation. From there I calculate the RPM's via the value of the Pulsein measurement. At the higher RPM, lets say 2000 the value changes to 480, and 4000 RPM the value changes to 240. The higher RPM I loose accuracy, but I could care a less on 50 RPM or so. My Max RPM is about 6200 RPM (Can go to 6600, but it would have to be without the prop). At 8000 RPM, the Value is 120... Thus you have 120 values that represent 4000 RPM (at Highest speed) 4000/120 = 33 RPM per increment...
    Dwayne
    Ability to Fly:
  1. Replies: 5
    Last Post: - 16th October 2009, 19:29
  2. Digital Out on an A/D pin safe ?
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 21st January 2009, 23:48
  3. analog and digital
    Last Post: - 10th June 2008, 03:40
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. Digital IC Tester
    Last Post: - 18th September 2006, 04:38
