Problems with 16F684
Results 1 to 27 of 27
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Problems with 16F684
    Strange ...
    I have no errors on compiling...just not work !
    Dec 2008
    Ploiesti, ROMANIA
    With code from post #1, I build this thermo-voltmeter for using in car.
    Note : for "I(nside)" I dont have anymore DS18B20 sensor...
    Jan 2010
    Congratulation, Fratello!
    Good work.
    Hi, Fratello
    I just think ISIS doesn't appreciate you do not wait for DS1820 temp conversion complete to continue running your code ...
    not a real problem ( Mikroelektronika lets it as-is in its onewire drivers ... booooo )
    in easy words, ....Change
    Main :
     OWOut DQ1, 1, [$CC, $44]
     OWOut DQ1, 1, [$CC, $BE]
     OWIn DQ1, 2, [temperature1.byte0, temperature1.byte1]
    for
    ' Start temperature conversion
     OWOut DQ1, 1, [$CC, $44 ]
    ' Check for still busy converting
    waitloop:
     OWIn DQ1, 4, [Busy]        ' Check for still busy converting
     Pause 95         ' Slow Down to actual Conv. time
     If NOT Busy Then waitloop
    ' Read the temperature
     OWOut DQ1, 1, [$CC, $BE ]
    you will display the very last correct measurement and not get " 85°C" or junk at power up ...
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much for help !
    I give up to use "LCD_AnyPin" ... since don't work (see post above, #14) ! I use "classic" hardware, with good results ! And I made one good PCB too...
    Best regards !
    Jan 2010
    You made that PCB in Proteus?
    Dec 2008
    Ploiesti, ROMANIA
    Oh, no ! In SprintLayout !
